Old Delta water bath powered grinder
eliot d
>I use 8 inch grinding wheels with the Wolverine sharpening system and also the Tormec. But I came across this old Delta grinding station in the back of my shop that I had more or less forgotten about. It has a large wide white wheel that turns very slowly in a water bath and a small narrow friable white wheel that turns fast. Does anyone use this any more? I'm thinking about using it in a separate shop at my daughter's house when I go there to visit.
Re: Old Delta water bath powered grinder
Richard Allen
Richard Allen
>You will do better to replicate what you use at home. That will eliminate one of the frustrations you will have working away from your shop.
I tend to use a lot of tools in my shop. So many tools that I can't really identify all the tools I need to take with me. SO I tend to take a lot more tools than I need when doing woodturning away from my shop. And even with all those tools I take with me there are still tools I reach for.
Your style of turning may be better suited to working away from your shop.
Wilford Bickel
>I have one sitting right beside my slow speed Woodcraft grinder. I love the water wheel for honing edges - especially for those final cuts you want so smooth and tools like skews. I used just this unit a year or so before I got the Woodcraft but believe having both of them is the best of both worlds!
eliot d
>So it's quite useful! I'm glad to hear it. Mine is slightly dished in the middle of the large wheel. Can you say how to level it out? There are several attachments for my Tormec to true up that wheel, but I'm not aware of any for the Delta.
Re: Old Delta water bath powered grinder *LINK*
Wilford Bickel
>Diamond T wheel dresser - lots of sources - cheapest I have found is Lee Valley. Just hold flat against table and let it level it up.
T Dresser
Clarification *LINK*
Wilford Bickel
>Just making sure - my Delta model has the large wet wheel running in a vertical direction like a regular grinder. They make one with the big wet wheel on it's side that is useless for turning tools -- made strictly for planer blades etc.
Mine
Re: Clarification
eliot d
>Yours is the same as mine. Thanks for responding.
Re: Clarification
Wilford Bickel
>Eliot,
Just remembered one thing - when I set mine up for honing I fixed it where the wheel turns away from the tool. This keeps the edges from digging into the soft stone and really gives you a polished honed edge. IIRC I had to tap one hole in mine to shift the table to this side of the wheel.
I was a young man when I started....
Ron McKinley
>I bought one a few years ago and started sharpening lathe tools with it. I was a young man when I started but by the time I finished I was on Social Security! ........Ron
Re: I was a young man when I started....
eliot d
>I guess you have been turning a while. What kind of turnings do you usually do? How do you like sharpening lathe tools on the Delta?
Wilford Bickel
>Ron,
That is why I have both the Woodcraft Slow speed grinder and this Delta Unit. The Delta does put a good honed edge on that you cannot get with just a grinder.
Attachment for Delta... *LINK*
Peter Teubel
>Woodcraft sells an attachment for the Delta wet grinder that allows you to use all your Tormec attachments on it.
Tormek Jig Adaptor for Delta
Ron McKinley
>That was tongue-in-cheek and I was referring to how long it takes to sharpen a lathe tool on a slow speed wet grinder........Ron
