Quick Q: will it hurt to use my lathe just today?
Ruth Niles
Re: Quick Q: will it hurt to use my lathe just today?
Bob Fawcett
>Even if it is bearings, I doubt using it today would make it much worse. Of course if the sound chages or anything else strange happens, turn it off.
I Can't Wait To Hear About It If You Do !!!!
Ken Oakley-Sunny St. Cloud, Fla.
Re: I Can't Wait To Hear About It If You Do !!!!
>I agree with Bob. If it's bearing the worse that will happen would be excessive chatter or locking up. Either way you would have to replace them. I would listen for unusual noises and stop and look if you do hear something worse.
Thanks, Bob and John........
Ruth Niles
>I just have 6 small jobs that need to get done, nothing out of round or off balance, so I didn't think it would hurt.
Ken, you will be the first to hear about anything adverse that happens, promise. ; )
Re: Thanks, Bob and John........
Now you sound just like my wife----daily or hourly sometimes
I sense a new story about to unfold on WC!
Molly Winton
Wilford Bickel
>Keep a good check for the spindle shaft or bearings getting hot. IF you should have a bearing lock totally up and start spinning the spindle in the inner race you could gall it and have to rebuild/replace it also. Secondly a locked up bearing could spin in the cast housing and cause it to have to be repaired. As long as nothing is getting HOT to the touch you should be fine. I sure would not push it far before I get to the bottom of it.
