THE WOODRAT IS BACK!
Long spindle split?
Long spindle split?
Long spindle split?
John Kyler
>I have a spindle I need to turn that exceeds the length capacity of any standard lathe I have access too. It appears the original was turned in two parts and then joined together. Those who have done this, what is the best way to do this? I plan at this point to turn both pieces and drill a hole in both ends that join and glue a dowel. Any other suggestions?
TIA
John
Re: Long spindle split?
JanManuel
>I would suggest drilling your holes first, then turning "around" that hole. That way, when you insert the dowel, it is perfectly centered. The other option is to drill one side only, and turn a matching tenon on the other half of the spindle.
>I agree with Janmanual.
I made some canes recently and they had a brass connection in them like the ones in "break down" pool cues. I tried turning the canes and then drill the holes. Never could get them good enough. Then I tried drilling the holes and using them as centers. Better, but still not good enough. I ended up mounding the fittings in the blanks and gripping them to turn the canes.
What I found was that really good accuracy was necessary. If you have the holes off even a little it really shows. If they are angled, Murphy's Law says the angles will add up and not cancel each other and your piece will have a bend in it like a knee. IF they are off center, again, one will be left and the other right and the effect will be doubled.
I would drill a really accurate (as in straight in and at least paralel to the axis) hole in one piece. I would turn a dowel to fit in the hole and then use that dowel as a drive center. Then I would turn a matching dowel on the other piece. Then if all else fails and your pieces still are not straight, you can reduce the size of the tenon slightly and fill the gap with epoxy, giving you a little �wiggle room� to center up and straighten it.
mortise and tenon joint
>I have just written a short aticle on how I do a mortise and tenon joint. I will send it to WC for the articles section and also post it on our club website. Both of those will take a while so if you want the whole article send me an e-mail and I'll send it to you. Here is a photo of the joint.
I drill the hole on the lathe and make a tenon that goes into my chuck to drive the wood. This uses the hole as the center so the piece will fit together very accurately.
Re: mortise and tenon joint
>This is the drive tenon installed in the chuck. Make it a snug fit so it will drive the wood. Too snug and you'll split the wood, too lose and it won't drive the wood.
To make the tenon I push the wood onto the spinning tenon. this burnishes and area to show me exactly how big to make the rest of the tenon. Then I sneak up on it checking it frequently. The small shoulders push against the face of the spindle to drive it.
the finished joint.
>Disquise the joint by putting it between two mating elements. It's almost impossible to hide it when the wood is smooth. Many people simply burn 3 or 4 lines with wire making one of the lines the joint. Here I put it between 2 beads.
Please excuse the look of the joint. In my rush to put these together I forgot to square up one end. I didn't glue the joint either so turning the beads on a piece of wood 2 feet long and 1" diameter with a weak joint in the middle cause a little chatter. You get the idea I hope. If not e-mail me and I'll send the whole the article.
