latest "project"
eaglesc
>Time for another Gent.
The main blank is Holly thansk to Ron in Drums, with aspen "mortar joints"
Inside view of the inlay
latest "project"
eaglesc
Unbelievable, Eagle !!!
Dennis Yoder
Re: How'd you do the blue?
>I like them. I think the color combinations are really nice.
Re: latest "project"
IAN
>eagle,
excellent work a usual, your eye for the layout is fantastic.
how did you do, or what did you use for the blue sections?
IAN
eaglesc
>White wood that I dye blue
WOW
Peter Teubel
>Now that is a beauty! Excellent work.
Ian
>thanks eagle
ian
RevDoug
>Truely inspired. Very nice work, Eagle. You are indeed an artist.
Turn 'em round,
Tommy Holmes
>Eagle,
Beautiful work as always. You have got to post a tutorial on how you do this.
eaglesc
>"You have got to post a tutorial on how you do this. "
Actually I dont.
Not because I am trying to be a "Smart alec" but because one is not necessary.
If you break down this blank It is a picture comprised of thin strips of wood I dye and dimension myself.cut on a Dremel scroll saw I bought used.
Each piece is glued in one or two at a time.
Every cut is made on a 90.
The blank the inlay goes into is a variation of aspiral segment.
All tolled the inlay took about 3 weeks to make and if I am lucky will yield two pens.
Worse case scenario I will get no pens.
Let me explain.
The finished pen Pictured is selling in excess of $1000.There is no way I can break that down to a dollar per hour figure.Considering the time designing the piece,and execution I would probably be working for less than minimmum wage.
Just prepping the wood takes a considerable amoount of time.I could buy predyed veneers but then I am constricted to a thickness that may or may not be of my choosing.The fact I can dye my own colors gives me grater flexibility.
As for the inlay itself It starts with the idea, then a sketch, then a scaled drawing sized so it will fit in a given pen and not be turned off when turning.
As far as the "picture" goes,each piece needs to be thicknessed to fit in a kerf of a given size.Some of the blades of grass in the foreground are .010 thick(I checked to make sure the decimal was in the right place) That's equal to 2 pieces of paper, actually a little thinner.
Between each cut the blank needs to be triimed and the excess glue cleaned off without changing the "face" of the blank so the ensuing cuts are"plumb"
All that describes the inlay itself.
Then there is the blank the inlay goes into.
Many would be happy to make a spiral segment and complete a pen from it.
I decided to take that one step further and put a big gaping hole in it and add the in lay.
This is the "money cut"
At this point I can totally ruin what took weeks to make to get to this stage.
The second"money cut" is putting a skew to it to turn round for drilling.
The last "money cuts" are the drilling.It must be drilled center to the pattern.CSUA reccomends a 7/8ths blank for a Gent.What you see pictured is how I Drilled it.The blank was .74" and drilled with a 37/64ths split bit( thank you Drill Dr!)In one shot no pilot hole.(Brad point bits have no business in a my shop where most work is drilling end grain.You are just looking for trouble))
Should anything happen on the lower section I can make another one of those easily but still time consuming.
The upper barrel is another story.A mistake here and it is usually back to sqaure one.
All of this and we havent glued the tube, milled the ends, or tuned anything close to final dimension let alone the time spent sanding and finishing.
ALso not mentined in all of the any cost for the raw materials.
A blank like the ones pictured would be in excess of $300.00 and I am not sure I would make one for like those for someone else even if the money was up front with a 2 month wait.
I have considered selling a blank similar to Pentarsia.
I am not sure if it will have all the same features but I would try to incorporate most of the design aspects.
In a way because of its' size Pentarsia is more difficult.
There are more "money cuts" concerning the loop in the cross and the ring that goes through it.
A blank like Pentaria would be ball park $100.00 but there would not be many for sale as they are done one at a time.
Should a buyer want them drilled, that would cost more.
Ron in Drums PA
>Looking Good Eagle!
Tommy Holmes
>Gosh Eagle, that was a nice short tutorial....:) Expand just a little bit and add some pictures. It would really be great. It really is interesting work and just unbelievable.
Allen Neighbors
>eagle, you do exceptional work. You have steadier hands and a lot more patience than an ORAF! :)
Nice work. Done well.
eaglesc
>Thank you... (I think).
What's an ORAF?
Re: Old Retired Army Fart..... :)
Allen Neighbors
Re: Oohhh NO!!! Its the dreaded blue ....
Jamie Donaldson
>.. background disease, the one that turns the wood, shadows, and highlights BLUE!!!! Be gone from my eyes forever!!! ;-)))
Randy G
>Another Great looking pen Eagle, Nice work
