Scrapers
Scrapers
Scrapers
Ron McKinley
>What's the optimum grind angle for a scraper? I've just been matching the angle they come with. I use them primarily for hollowing small boxes and bowls. However, I ran across a website where he mentioned that he grinds a 45 degree angle on his and he uses them on the outside of spindle type projects like bottle stoppers. Thanks.........Ron
Re: Scrapers
Re: Scrapers
Brian Hahn in SW Wisconsin
>I grind mine about 70 degrees (included angle at cutting edge). That seems to be a commonly recommended angle.
Re: Scrapers
Re: Scrapers
Wally Dickerman in Arizona
>30 degrees...or 60 degrees, depending on which way you are measuring.
Wally
Re: Scrapers
Re: Scrapers
Russ Fairfield
>As a general rule, the less the angle, the sharper the burr, and the better the finish it leaves on the wood; but the less the angle the less support there is under the burr, and the more likely it will break off rather than wear.
70-degrees is a good all around angle for a scraper. The 60-degrees that Wally mentions willo give a better finish cut. Whoever used the 45-degree angle has to be using a light touch and making light cuts because it will be very fragile; but it will give a superior finish on the wood.
Re: Scrapers
Re: Scrapers
>I use about 70 degrees on most of my scrapers but use 45 on the John Jordan Shear scraper. As Russ says it doesn't hold and edge long and you have to re establish the burr often but it leaves a fantastic finish on green wood vessels and convex bowl surfaces.
I never use a scraper on spindles. They simply don't give a good enough finish but I do teach students how to use them because it's a good thing to know. I use my scrapers mostly on bowls or vessels if I'm having a problem somewhere.
Re: Scrapers
Re: Scrapers
Ron McKinley
>Thanks to all. I measured mine last night at about 72 degrees. I think I'll grind one at 60 degrees and see what happens. Thanks again...Ron
Re: Scrapers
Keith Tompkins
Re: Scrapers
keith tompkins
>Ron, I wouldn't consider using a scraper for spindle turning...I don't know your skill level, but I can't think of any positive reasons for using a scraper on such items as the exterior of boxes or stoppers. The finish won't be as good, and the shape of the scraper will dictate the shape of the finished item. For example, beads and coves are hard to scrape, and will appear rough, and it will be difficult to sand satisfactorily leaving crisp, clean details. The more you begin to rely on the scraper, the less inclined you will become to practice with the detail gouge or skew. Pieces will take longer to produce with a scraper, and the results won't be as good. I had a student who turned items for craft shows, and wanted to improve his profitability. Bottlestoppers were taking up to 45 minutes each, mainly due to sanding out tool marks and torn grain. I showed him proper spindle turning techniques, including using the skew for cleanly cutting end grain. The last time we spoke....3 minutes each.
Re: Scrapers
Re: Scrapers
Ron McKinley
>Good advice Keith. Thanks. My skill level leaves a lot to be desired......Ron
