Half round scraper?
Doug Thompson near Cleveland
>Since we are talking unique tools, here's one I made a while back.
Good, bad or any comments...
Half round scraper?
Re: Half round scraper?
Jennifer@Indy.USA
>Doug that looks like something I could have use a million times! I'm thinking that I could make one out of an old shallow spindle gouge I have? Hmmm....
Those times you need a tiny scraper this would be ideal. I have a drawer full of old tools that I pick up a flea markets and stuff that I really need to "customize".
Thanks for the visual!
Jen
Brad Vietje
>Doug -- this looks like a useful scraping tool for small boxes and end-grain hollowing, but for what particular use did you design it? The important question to me is how well does it do what you want it to? As a small round-nose scraper, I'd probably have left a little more beef in the shaft, and only ground the flat about 1/2 as long for greater stiffness. 'Course I haven't used it, so maybe it's beefy enough already. If the sides are sharpened, it could also be a small-scale double-sided shear scraper.
Safe spinning,
Brad Vietje
Newbury, VT
Ed Heuslein
>Howdy Doug: This looks very similar to the "Skewchee Gouge" and "Spindlemaster" to me. Like Brad says, leaving a shorter flat portion will beef it up just a little. I have a couple I made. They work well for beads, coves, and getting in those really small places where nothing else will fit. The ones I've seen have a steeper grind however - 40 - 50 degrees.
>This was made to see if it works. To get a scale of this tool it's 5/8 diameter and the flute 3-1/2 inches. I have ground this with a round nose but I like the pointed tip a little better. One day I'll try a jig grind to a sharp point and see how that does.
As a scraper it works very well and what I like it can take some stock off like a gouge. I'll keep messing with it. When the rough stock is cut into lengths you end up with shorts that are to big to scrap and are perfect to experiment with.
