Band Saw Troubles - Long
don central illinois
>I have a Harbor Freight 14", model T32208. I was sawing a fairly wet log and the blade stuck. I shut it off a quickly as possible but it won't start. I have checked the circuit breaker and the outlet and it still has power. I have looked all over for a reset button and can't find it. Any suggestions as to what might be wrong? TIA.
Re: Band Saw Troubles - Long
sam nelson
>Hi Don
You did not say if the blade is still stuck in the wood. If it is you will have to free it up before it will start up. This has happened to me and I freed up the blade by prying upwards on the teeth using a flat screw driver. Yes it was hard on the teeth but I managed to free up the blade and remove it from the wood.
Take Care
Sam
Steve Kubien
Steve Kubien
>I have had something similar happen to me. The breaker was not tripped but I once I shut it off and then back on again, everything was ok. I also tend to shut off the neighbouring breakers. I know that's not much help but it's the best I've got. I don't understand electrons at all (should've listened to Venus Flytrap more closely).
Cheers,
Steve Kubien
Ajax, Ontario
Don in Central Illinois
>Should have been more explicit. I've removed the wood, tripped and reset the breakers, everything turns by hand, just no power. I would think there would be a reset button somewhere but can't find it on the machine nor in the manual.
RevDoug
>A couple of things to try. First, you may have to leave the saw disconnected from the power for more than a second. Unplug it for an hour or so and give it another try. Second, some electric motors, particularly replacement motors, have a reset button on the motor. You might check both ends of the motor for a white or red button. It should be just under the size of a dime.
Let us know what you find.
Turn 'em round,
rkc
>The same thing happened to me and I was convinced that I had burned out the motor...
I swapped in another motor that I had lying around, and it still wouldn't work... and at that point discovered that the switch was full of sawdust and had stopped working.
Worth checking....
>Good point, I'll check it tonight. Thanks. Hope that's all that's wrong.
Re: Dittos on the switch
Dale Stansbery
>I have the same saw and the switch collects dust insulating the contacts.
