In line filter on Air Comprerssor
Jennifer@Indy.USA
>Hey gang. I just posted this on the main forum but wanted to post it here to see what the turning side does in this case. Thanks!
I am wanting to put an in line filter on my AC in order to help in moisture control into some of the pneumatic tools I use on use on my turnings. I thought that the little filter I bought just connected onto the regulator at the AC, but apparently I need a short line coming form the AC...then they say to attach this filter to a solid surface such as the wall...and then run the extended line to the tools from there. So I'm at Lowes yesterday, and I don't see any sort of short air hose for the filter extension. Does everybody just make one of these out of a piece of short hose and use those coupling do-dads? The tapered thing that fits inside the hose to seal it? I fear those would leak...they always do when using them to splice garden hose. Perhaps I'm missing the entire explanation that came in the filter box...it was pretty sparse. Of course I just tossed my old air hose and the trash pick up was yesterday.
Any help would be most appreciated. Thanks!
Jen
Re: In line filter on Air Comprerssor
All the time...
Peter Teubel
>Most of my hoses are spliced. The only ones I do NOT splice are the ones that go to the tool itself. I found that the splice connection will leak after some (ab)use (i.e. swinging around a framer or impact wrench).
Re: In line filter on Air Comprerssor *LINK*
Wilford Bickel
>Stop by Harbor Freight and ask for a "Whip Hose" - it is a short piece about 3 foot long made for this type of application and hooking up a hose reel to a compressor. See the link and look up Item 1824..
Whip Hose
Perfect....thank you!
Jennifer@Indy.USA
Jim Swank
>Consider putting a lubricator in line after the filter if you're using air tools a lot - it'll prolong their live greatly. Beware if you do that the oil lube for the tools ends up in the air as mist whether you put a couple drops in by hand or use a lubricator.
Fog Tanner
>If you are looking for something to get rid of moisture, you might take a look at the automotive paint supply places. I use a small ball looking filter that has a female fitting that screws on the end of the gun and a male fitting that lets me connect to the airline. These are small and compact and eliminate the moisture where you are using it.
I also have a regualtor and filter/dryer mounted on a stand made from PVC that the main airline plugs into and there is a 15' hose connected to the outlet side of the filter. I did all this mainly for painting where I needed to regulate the air pressure and keep the moisture out. But it would work equally as well on air tools.
