Changing the blade on Jerry's old handles
Doug Thompson near Cleveland
>The Blade can be easily replaced in Jerry's red or black handles if you follow a few simple steps.
First clamp the handle in a wood jaw vise with the tip of the blade pointed up so the shot will remain the handle.
Now heat the handle evenly from the blade to about 2 inches down with a propane torch, this will take a couple minutes. Grab onto the blade with vise-grips or channel locks and try to twist the blade, if it doesn't move it's not hot enough to melt the epoxy. If it does start to move you have about one minute to go with the heat. DO NOT yank, tug or use excessive force to remove the blade (DAMHIK), when the epoxy is melted the blade will slide right out of the handle. Remember the handle and blade are hot as a firecracker so don't touch them. Most handles have a bushing that the blade fits in, try to keep this in the handle.
To replace the blade, let the handle cool down then remove the old epoxy, mix up some new epoxy and glue the replacement blade in the handle... let it dry.
Did I forget anything...
Re: Changing the blade on Jerry's old handles
Dave Shombert
Once it's out ......
Dave Shombert
>Good description, Doug.
Does anyone know if the new folks who took over Glaser's operation are going to make the tools available unhandled, as Jerry used to do, and are they going to be the same size (i.e., useable in our old handles)? Last time I talked to Brad Packard about this, maybe six months ago, he still had not gotten an answer from them on this topic.
Dave Shombert
Elkins, WV
Re: Once it's out ......
Mark Kauder, Phenix City, AL
>Dave,
I do not know either, but I do know that Doug makes some extremely fine gouges that will go in there.
Mark
Rick Allen
>Hi Dave
Why not send an e-mail to CET and get an answer from the source rather than second hand information?
information@cetinc.com
Don in Central Illinois
>What is the best way to remove the old epoxy after the blade is out?
>Don, after the blade is removed the epoxy is still soft and can be scraped out with a scrap of wood.
>Thanks. I've not used a lot of epoxy, especially in tool handles and was curious.
