We value your privacy.
We had the aweaome MR LANCASTER down to out club recently and for some reaswon I remember hinm stating IF it is dried to remover the tip of the cutter. May want to get a second opinion! I would call him! I have and he picks up the phone and answers questions. He is the expert!!!
>I know nothing about the easy core system, but if you cut into this, and turn any of it, there will be a little change/warping/etc., but not too much. It's just like when you plane a flat board... if you don't take a little off both sides the movement will be worse.
I think you could core them a lot thinner than the 10% rule, and not be hurt by it.
>I think that there shouldn't be any problems with coring that wood. With dry wood you may want to have the dust collector going. Air dried wood will cut easier than kiln dried wood. Your feed rate with the coring tool will probably be slower than with green wood. As far as the point on the cutter, (after talking to Ken at Oneway) it is kind of like a chip breaker, which tears/cuts through the fiber, and the flat part of the cutter cuts and removes the broken chips. Now,for me, I have found those cutters a pain to sharpen. I had Oneway send me one of the cutters that hadn't been shaped with the point on it. I ground it to a shape with a square front, and tapered sides (front wider than the sides). I can sharpen it without removing it from the blade. It is much more agressive in its cutting than the pointed ones. While I haven't had it happen to me, I can see that if I apply a lot of pressure on the handle, this point could catch. With the standard cutters from Oneway, if you grind the point off, you still will have to remove the cutter from the blade because the face of it is flush with the blade.
