We value your privacy.
>The other day I was turning a piece and at the time I was using a small gouge. I took it into a tight place but was trying to get a little sheer. It occurred to me that a bowl gouge, cut in half lengthwise might be interesting. Has anyone tried that? Dumb idea?
I guess you would need two of them for each direction of work. Well anyway, it was just a crazy thought at the moment.
Funny you should ask that, I have done exactly what you mention. I approached the idea differently, however. I thought it would be neat to have a skew-like tool but with a slightly curved edge and just a bit of a hollow, or a flute with a broad curve like a continental spindle gouge. My intention was a bowl skew, to make a final clean cut on the interior of a bowl. I made a prototype with 3/8" HSS shaft, grinding a short and broadly-curved flute, and an angled edge like a skew but with a single bevel like a gouge. I did make a double-ender, a left-hand and a right-hand tool. It worked really well, especially with a honed and polished edge.
I thought I was on to something big, and imagined myself on the cover of the Craft Supplies catalog, showing the Grunke Bowl Skew. My delusions of grandeur lasted only a couple hours until I looked at one of my gouges and realized that my new skewgouge was nothing more than a regular gouge split down the middle.
Still, the idea was a good one and I reach for the double-ender occasionally. It goes in one of my setscrew handles, and I use it mostly for spindle turning rather than bowls.
>Thanks for your reply. Yes, that is similar to what I was imagining. Basically a bowl gouge split down the middle. My thinking is that you could get some cuts in tight areas without the extra width of the other half of the gouge and also be able to avoid catches.
Go ahead and develop it...the Grunke tool just might be a hit! :-)
>That's pretty much it Mark. A broad, shallow flute leaving more than half of the metal below it, and an edge angled like a skew instead of a symmetrical spoon-like shape that a detail gouge has.
>Interesting tool. I would be nervous about catching the long point. On the outside of a bowl it would be a lot of fun to use but on the inside I think I would prefer to try something more like a spindle gouge but maybe with a convex curve to the bevel like Russ suggested. I like the idea of leaving the shaft fully round. This would reduce the vibration considerably.
I'll look for the Grunke tool at my local Woodcraft. :)
>You never know until you try. We use standard shape tools because no one has come up with anything better. Draw it out and when I have time I'll mill them... It just might work.
>Here's a sketch, Doug, of my idea. My prototype was only 3/8" dia. shaft, 1/2" would be much better. It should have a long bevel like a skew, with an angled edge like one, but mildly curved. The flute should be shallow and of a radius about equal to the shaft's diameter or a bit more. There should be a right and a left-hand edge, maybe both on the same shaft. Call it what you will!
