Chalice
Joe Donohue
>I have been asked to make a chalice and matching plate for use in a prison ministry. It does not have to be fancy but it will be used.
Any suggestions as to wood species, finish, lack of same?
Thanks
Joe Donohue
Chalice
Joe Donohue
Thanks
Joe Donohue
Re: Chalice
Rich Egan
>Joe: My understanding is that a chalice needs to be made of metal or glass or some other material which will not absorb liquid. Once consecrated, it must be entirely consumed. A wooden chalice would need a liner of some kind, and even then, I'm not sure it would be allowed?
Re: Chalice
Ken Romines
>Joe
You actually have a choice. No longer than the chalice will hold wine/grape juice you can use an epoxy finish. Check with any of the big name epoxy makers.
You can also make one out of corian that has been glued up like a segmented hf. And someone on this forum mentioned that they lined their turnings with either glass or plastic.
The plate can have an oil/wax finish as can the outside of the chalice.
Send pictures when you are finished.
Ken
Re: Chalice
Bill Hale / The Wood Spinner
>I have made a chalice for use in a special service. I used Maple burl and finished with an exterior varnish. The client was very happy and it did not stain.
Look them up on the web as there is a specific size and special shape. It should be gold lined but I did not do that to mine.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Chalice
Mark Paulley
>Joe,
Go to a Dollar Tree store and get a wine glass and cut the stand/bottom off, thus leaving you with a glass and a stem. Next shape a hollow vessel that will hold the glass. Drill down into piece a tad larger then the diameter of the stem to fit into the wood. If you want to jazz it up a piece cover the inside of the hollow form with 22K gold leaf then glue the glass into place. Thus you get the gold look and a non-staineable chalice. You can even leave a bit of the glass ticking up above the wood, that way the lips only touch the glass and not the wood. Just a thought
Mark
Re: Chalice
Gil Jones on Lake Seminole GA
>This is turned from Crab Apple, but a glass brandy sniffer upper part set in wood might be better for actual use.
The only problem I might have with that idea is that glass would not be a safe material in a prison environment.
Re: Chalice
Karen F.
>I work in a jail in my state. I would make sure you check with the Deputies or Officers running the prison that is would be OK to bring in these items. I also know we have numerous diseases running through our inmates that would easily be passed from one to another. You need to be aware that you(and your group)could be held liable if someone says your "cup" gave it to them. I would suggest a platter to hold small paper cups. Just a thought with all of the jailhouse lawyers out there.
Re: Chalice
Joe Donohue
>Thank you all for the suggestions.
I will have to clarify the requirements with the client as to use. I assume the client will take care of permission for use because I really don't know which prison (or prisons).
I will update here when I het further,
Thanks
Joe Donohue
