Pyrography Pens OT a bit
Tom Storey
>This is a copy of my post to a woodburning forum. Not many replies. Any help here?
I do some wood turning and I want to do pyrography decorating on some pieces. This would involve burning a series of circles of various diameters, just like an 'O', and unfilled. I'm thinking diameters of 1/8 inch or less and larger, say up to a 1/2 inch.
I am also interested in other tips with shapes like squares, ovals, Xes and so on.
The reason for the pre-formed shape is to ensure a near identical pattern. If I get this done properly then I'll try some freehand decorations, after I do a lot of practicing!
I have a Razortip two pen system.
Anyone know if pens or pen tips are available for my system in the shapes I described? or are there workarounds?
Thanks, Tom
Re: Pyrography Pens OT a bit
Re: Pyrography Pens OT a bit *LINK*
Tommy Holmes
>I know nothing about pyrography. I did buy a burning unit a short while ago but have not got around to using it. The link that I attached must have 75 or more different tips. You might look and see if they have what you need. Hope it helps.
http://www.nedraspyrography.com/RazertipPenStore.htm
Rick Allen
>The pens that Tommy pointed you to include small squares and circles. You can also get some in the Detail Master brand. The guy who makes Optima pens will very likely make the shapes you are after. There is also the razortip "make your own", which you can attach a piece of nichrome wire to that you bend to the shape you are looking for. If you look around the internet you can find instructions on making your own pens.
I have used the small circle stamps. They work well but take practice to achieve an even clean burn. You have to figure that anything you hold in your hand involves a learning curve. Working on a natural material like wood will present different burn characteristics on different portions of the wood, more learning curve.
Optima pens
Don O.
>Go to the "WC Articles" section on the left side of the screen in the red area and check out the Woodturning techniques section. There is an excellent article on pyrography incliding info on making your own pens to suit your needs.
Hope this helps.
Easy to Make
Jennifer@Indy.USA
>Hi Tom,
There is a pen made by Razor-tip that accommodates some of their own "Stamp" designs. It's called a Create-A-Tip. I've purchased several of their stamps but then realized that I could easily make them myself. Some Nichrome wire, silver solder and some brass or copper tubing and you've got a ton of them in a variety of sizes. Here's some pictures of mine. Razor-Tip sells square ones and round ones on their site. You'll need to search for "STAMPS".
I make mine with different shaped tubing from a hobby store here in Indy. The copper tube works the best, but the brass works too. It just takes more heat to get it hot enough. They are then used in the Razor-Tip "Create a Tip" pen. They are really fun to make.
Good luck!
Jennifer
Another Pic....
Jennifer@Indy.USA
>A closer look......
For larger Stamps...
Jennifer@Indy.USA
>Tom, I just realized you are also looking for larger ones. I needed a 3/4" circle stamp on a platter I made a while back and since that would obviously be way too big for a woodburning unit to heat up...I just took some copper pipe, cut off about 2" and then crimped one end...leaving the other end round, held it with a pair of Vise Grips and then heated it up with a torch until it got hot enough to make the burn. Place it on the piece...and you have a nice circle!
Jen
Re: For larger Stamps...
jeff myroup
>I never thought of that. Did you sharpen the end or just leave it flat?
Jeff
Jennifer@Indy.USA
>Jeff,
I left them flat. I didn't think to sharpen them...but I don't think that would have given me any benefit for what I used it for. Here's the platter that I used the pipe on. The copper BB's are set inside the circles burned by the copper pipe. It is about 18" in diameter.
Jen
Tom Storey
>You do great work Jennifer! Thanks all for the help!
Tom
jeff myroup
>Thanks Jen. I really like the "straw" effect around the circles, along with the rest of the platter. I really need to pick up a burnning set.
Jeff
Mark Paulley
>Jennifer,
Do you do classes or demos on Pyrography?
Mark
