Stuck chuck insert
Stuck chuck insert
Stuck chuck insert
eliot d
>I can't get a chuck insert out of my chuck. I tried clamping the chuck in a wood vise and using a large wrench on the chuck insert, but it won't budge. I recall that a similar problem with a stuck faceplate was solved by putting ice on one part and heating the other. Was it heated with a blow torch? I'm afraid that a blow torch will damage the chuck.
Re: Stuck chuck insert
Gary in Zirconia, NC
>We need to know what chuck you have.
Ed Wujciak
>Make sure that there's no setscrew (grub screw) locking the insert in.
Steven Smith
>I am sure you have already checked by my chuck has a set screw locking the insert in place.
Re: Get Ruth to fix it!
Bill Turpin in WNC mountains
>She will bend a monkey, stilson, pipe wrench around it and it will be free in just a minute. Ha Ha
Is there a threaded push hole in your insert to pop it out?
Bill in WNC mountains
jeff myroup
>I have a oneway stronghold. I had the same problem. They are tapper fit. Make sure the set screws are removed. I then put it over a couple of 2x4's. Use a brass rod and a dead blow hammer and tap it out. You could also heat the chuck. a torch should not hurt it. just make sure ther is no finish or saw bust in the chuck.
Jeff
Wayne in Topanga
>My Stronghold chuck is a taper fit. There are 3 screws that lock it in place. To remove the adapter I remove the screws and move them to other holes and use them as jack screws.
Might not work for yours since I don't know what you have.
Happy Woodworking,
Wayne
That's the hard way...
Peter Teubel
>Remove the screws and thread them in the holes that are threaded in the ADAPTER (as opposed to the chuck body) and jack out the insert. Pops right out.
Re: Stuck chuck insert *LINK*
Gordon Seto
>The proper way to remove the insert is on pages 8 and 9 of the manual. It saves you a lot of hard work.
Gordon
Oneway chuck manual
eliot d
>I can't find a name on the chuck. It looks something like a small Oneway, but I know it isn't. It uses a bar to adjust and tighten the jaws.I think maybe an older Nova. It's black in color. (I attended a demo by Cindy Drozda once, and I remember that she liked that particular chuck and uses it.)
Anyway, the insert screws in; so I don't suppose I can use the jack screw method. A much more experienced turner ( and machinist) once got it out for me by just holding it a wood vice and using a wrench, As I said, that wouldn't work for me this time. I guess I'll try heating it.
If I can't get it out , which small chuck do you recommend for my new Jet mini lathe. I looked at a super nova in the store, but it was around $200. I paid only $219 for the lathe. I not ALL that cheap ( my chuck for the Powermatic is the large Vicmarc). But I am having trouble paying about as much for the chuck as for the lathe!
Gordon Seto
>Try penetrating oil, like BP Blast first. That will take time for the oil to soak in. Heating would be my last resort; you don't want your chuck not to run true.
If it is a Nova, consider the Nova Midi. All old Nova jaws would fit. This small chuck is around $90. Since you also have a Powermatic, most likely the mini is for small stuff.
Gordon
robert davis
>if it is a nova, the insert screws in
eliot d
>Exactly. And the screw-in insert is really stuck. I did put some supper low viscosity , special gun -type oil in there, and it's been setting a couple of days. So I'll try it again.
I can help..................
Ruth Niles
>I used a few new cuss words that I never did before and it worked to get the face plate off my lathe. : )
eliot d
>Guess what? I got it off, and I'd like to share what I did in the hope that it may help the other guy. I bought a product about five years ago that I hardly ever use. But it seemed to help this time. It's called MILTEC, a "Synthetic Based Metal Conditioner ("protects metal with a synthetic molecular bond'). I dribbled a bit into the stuck thread and let it sit a couple of days. Then I went back to holding the chuck in a wood vice and using a long wrench on the stuck insert. I helped my self by inserting the metal pry rod in the hole on the chuck so and rotated chuck so the that the rod jammed against the partly open wood vice jaw. That kept the chuck from moving when I banged it with a dead blow hammer. And it came off!
I have no affiliation with MILTEC. Their web page is http://www.miltec-1.com. This stuff ,according to the bottle, is used in crankcases, sump applications, motorcycle common sumps, two-cycle applications, automatic transmissions, and weapons. Bottle warns that the stuff contains synthetic hydrocarbon derivatives and is harmful or fatal if swallowed. All I can say about it is that it is extremely slippery and seems to soak into just about anything.
nailshooter
>Thanks for posting the resolution of that problem. I am more in the Ruth Niles "get a big wrench and a hammer" (sorry.. just kidding) camp, so something scientific is great to hear about.
Robert
