Maple Box (#086)
Maple Box (#086)
Maple Box (#086)
Greg Haugen
>Well, here is my third attempt-first success at box making. It's Hard Maple 1 7/8" diameter and 2 3/8" tall, finished with wax only on the inside and waterlox sealer and wax on the outside. I used a 3/8" Ray Key spindle gouge for the initial hollowing. Awesome grind on that tool!! Started sanding with 180 and went to 1000 grit with Briwax on every grit to help lubricate the sanding (helps to prevent heat checking) and practically eliminates dust. My first two attempts I was following another turner's theories with using scrapers exclusively for boxes. Didn't like it at all. I really enjoyed the spindle gouge and the wax on the paper really "cooled" the sanding. After I switched techniques the third one "turned" out ok. The fit of the lid is a great suction fit. I did add a "halo" bead to the lid. Comments welcome and appreciated.
Thanks,
Greg
Re: Maple Box (#086)
Brian M
>Nice, very clean cut on the inside of the lid. Why is it that a all turned objects, its the boxes you just want to pick up and play with?
Don in Central Illinois
>Because you never know what might be inside.
Mike Stafford
Mike Stafford
>Very nice, Greg. One thing I have found to help with the end grain is to freshly hone or sharpen your gouge right before you make your last cuts and you will greatly improve your quality of cut. I have several freshly sharpened gouges at the ready and use them in order and then sharpend them all when I sharpen one.
The wax trick really works well. I also clean off the residue between grits before going to the next.
That is one sweet little bead on the top. Love it!!
jeff myroup
>Nice looking box Greg. Do you have any problem using wax as a lube for sanding and then applying finish other than wax? Do you clean it off first?
Jeff
Greg Haugen
>No. I haven't had a problem with it at all. It's not like the wood gets packed with wax. You're sanding, so it lubricates the sanding and also collects the dust but doesn't "wax" up the wood. Finishes are not a problem. This isn't a new technique by any standard. This is something that I've picked up from Ray Key Box videos.
Hope that answers your question.
Greg
jeff myroup
>Sure does, thanks, I will have to try it.
eliot d
>I have a couple of questions about using wax between sanding steps: are you sanding by hand or power sanding. If power sanding, do you have to toss the sanding disks? Finally, why Briwax? Would the method work as well with other kinds of wax?
Greg Haugen
>Ok, I'm handing sanding with wax on the paper as I'm sanding, not between sandings. By hand sanding with the wax the piece stays cool so your not fighting expansion from the heat, dust is also eliminated pratically. Why Briwax? That's what I was told to use for sanding and for finishing by Ray Key. It's a soft wax, most other paste waxes are harder than Briwax in paste form. Also gives a nice "satin" sheen and it's glossy.
Hope that answers your question. Ray's Basic Box DVD from Craft Supplies talks about it in depth.
Greg
