We value your privacy.
>A friend took down a 20-year-old paulownia tree recently and gave me a pickup-load of chunks and crotches to play with. I had never turned it before. I just wanted to mention that the dust and the wet cutoffs are murder on ferrous materials (can you say bandsaw table and blade?), and if you don't wipe them down within a day or so, you will have rust and caked-on gunk to deal with later.
Turningwise, it is almost as stringy as cottonwood, but not quite. I have no idea how this vessel is going to turn out.
>...the wood's natural features get to stand for themselves. I love turning pieces from green to finish because the warping and checking and other movement add a dimension to the piece that is true to that wood. If you go through the rough turning and drying phase to get a perfectly round bowl or vessel, you lose the drama of this shrinkage property of the wood.
Curly wood shrinks to a wonderful, tactual surface when you turn it green to finish. Likewise for other figures. And when you get a wood with extreme differences between the radial and tangential shrinkage coefficients, like holly and dogwood, you have a whole other dimension to design with. In my experience, it doesn't always work if you let the pith go horizontally through the wood (bowl orientation), but if you are fastidious about mounting the blank before any checking has had a chance to propagate, however slightly, you can virtually eliminate checks if you turn green to finish.
Don't mind me carrying on here. I just enjoy the heck out of turning and I relish all the modes of expression I can find. Can't wait to try out the woodburning and piercing and painting that I see so much of these days.
>The first piece that I ever found to turn was from the stump of a pretty large tree. It had a wonderful large curly figure. Since then, every-time I see a good size tree, I always look to see if the stump is figured, and it usually is, so don't let that part go to waste.
Also, this tree can grow just about anywhere, and is the fastest growing tree I have seen here in Arkansas. Some I have seen had annual rings over 1.5" across, for a 3" increase in diameter per year.
