We value your privacy.
>I just noticed the 'coffee ground' question and I'm unsure of wet sanding. Can someone give me the quick lowdown? Do you use water, laquer or BLO, or what? I have been wanting to experment, but have too much other stuff going on, so I'm asking the experts. Thanks in advance.
>You can use water, I have used this before on green wood with no problems. I use mineral spirits on dry wood and clean the piece with Napa afterwards. I had no problem with the finish afterwards. 3M silcon carbide paper works great. You can easily find grits 180 to 800. You can also get 1200 and 2000, these were made for color sanding automotive paints. The 2000 is more for wet sanding some of the clear coats (there is one I use than can be sanded and compunded). Whether I use water or mineral spirits I put a piece of cardboard over the ways.
Speed is down around 200-400, depending on what I am doing. Higer RPM just buys you a wet workshop. Wipe the piece off inbetween grits to get rid of any of the courser grit. Don't go up by more than 50% of the prev grit (180 -> 220/240 -> 320 -> 400 -> 500/600 -> 800 -> 1200). You can also pick up a rubber sanding pad from an automotive paint supply. This is handy for doing large surfaces such as a bowl. You will get a much better surface than just using your hand. It speads the "load" across the paper and leaves a flatter surface.
>What you use as a lubricant depends on what you want it to do. They all have their uses.
Use water if you want to sand and raise the grain. Use Mineral Spirits of you want to see the sanding scratches. Use wax if you don't want to see the scratches longer and not raise the grain. Use Boiled Linseed Oil if you want to accent the grain. Use an oil finish if you want to accent the grain and start building the finish as you sand. Use Medium CA glue if you want to harden the wood, fill the grain, and fill cracks and voids all at the same time. Use lacquer and shellac at the risk of creating a mess.
>Be carefull sanding light colored porous woods with gray wet or dry paper. It will sometimes fill the pores with that color. When I wet sand I have usually applied one or more coats of some finish. It may be an oil finish or it may be a build type finish such as lacquer.
On an oil finish I usually use that oil as my lubricant for addtional coats and sanding. For Lacquer I use Murpy's oil unless I'm going to add more coats of finish. For the first few sandings of a lacquer finish I will use water. These are just leveling sandings. Once I get it level I don't sand anymore until I've built all the finish.
>Any sandpaper can be used with a lubricant. The only difference is that the "black paper" has a waterproof binder holding the grit to the paper backing.
Regular sandpaper is not waterproof and the grit comes off the paper, the slurry of grit particles sand just as well, and sometimes I think it is better. The only difference is that there is more mess to clean up, and the paper can't be used again.
