Coffee grounds and CA patch question
>For those of you who use coffee grounds and CA to fill voids:
If it fresh coffee or old used grounds you dried out?
What thickness of CA do you use?
Anything else I need to know?
Thanks.
Thanks.
Re: Coffee grounds and CA patch question
Russ Fairfield
>For what it's worth, I have had better results from fresh coffee than those that have been used. Fresh ground acts as its own accelerator, used grounds aren't as dependable.
I buy a standard grind and then regrind them in a little spice grinder to whatever I want. A finer grind works better for filling voids. A mixture of various sized particles looks better when simulating bark.
I coat the area with Medium CA glue and dip it into the grounds if I am adding, or pack them into the hole if I am filling. Then I wet the grounds with Thin CA glue to finish the job. The glue cures almost immediately without foaming when the grounds are fresh. Used grounds take longer and sometimes require an accelerator, and that can cause foaming.
That's how I do it. I am sure there will be others who will post a better way
RevDoug
>Russ has told you how I do it. Works great. Let us see how it works for you.
Turn 'em round,
Philip Morris
>Barry,
I have used dried spent grounds in the past (don't ask how fine, I just steal them from the wife's coffee maker). I fill the void with the grounds where they are slightly above the surface of the rest of the wood. I then drip water-thin CA glue over the grounds until saturated.
Couple of other considerations:
- I avoid using accelerator. It can cause white bubbles to form in the glue.
- If the crack is real large and/or deep you may have to do in stages to ensure good penetration of the glue.
- If the crack goes all the way through you may need to back one side with tape.
- Try to do this before you begin sanding.
- The super glue will leave a glossy surface, which means it will be visible if you use a matte finish on your turning.
Keith Newton
>Barry, I am not sure that there is anything magical about coffee grounds. You can use dust from your sanders if you have cracks or checks. Sometimes I will flood the smaller checks, then just wet sand with a medium grit paper diagonally to the split.
This will load the paper pretty fast, but will also fill the crack with the dust form the wood surrounding the split, and ends up just looking like streak in the wood.
Wolf Kiessling
>I guess nobody else does this but whenever I use coffee grounds to fill large voids, I mix the grounds with 5 min expoxy, overfill the whole and two hours later sand it flush with the surface.
Re: I do!
Andy DiPietro
>I just started using 5 min epoxy with coffee grinds. Check out my before and after pics on my April 29th posting. I gave up using CA glue and coffee since the CA will chip out a little during sanding and the epoxy stays solid and does not shrink.
Andy DiPietro
I do, too.
nailshooter
>I have been using ground coffee for years. I buy whole beans and fine tune the color I want with a heat gun, then grind. You can go from a medium brown, to a perfect black. Mix with epoxy, fill, when cured sand away.
On more rustic, natural work with many occlusions and "features", I don't grind as fine and you can see some of the coffee particles in the filler. On more finished pieces where I am mostly looking for the color to use as filler, I grind it to powder.
Robert
robert davis
>use recycled grounds. make apaste with model cement for wood models work in with small spatula. wery small amount at a time. AFTERsome kind of seal cote on the lathe
Jim Swank
>About the same here, except that I di the filling before a final shear cut to finish. This brings it back to a flush surface and removes nearly all of the overflow that might show in the finish. I can usually fill in any chips or voids by touching with a small drop of straight CA on the end of a toothpick and have minimal clean-up to do afterward. You may have to drop down a level or 2 in grit for your first sanding if you use CA as filler. I've never ben good enough to start at 400 anyway. Even if I were, I'd make the first pass at 120 or coarser for a good cleanup of any bleed over.
Thanks, Guys
>I just realized I failed to confess that this is actually for flat work. I made a table as a wedding present for my cousin's daughter and she wanted the top to be walnut with lots of character. It had a number of knots and defects. Thus the need for filler. Hope the turners in the crowd don't fell used and abused. The legs of the table were turned if that makes you feel better. She is sanding and finishing the table herself. I filled the voids in the legs with sawdust and CA, but I left the top for her. I will send her some sawdust, but I thought she might like the coffee better, but I have never use it myself. Thanks again.
Allen Neighbors
>Barry, like Russ and a few others, I use fresh coffee grounds. I made a mortar and pestle from Osage Orange and grind it as fine as I want it. Before I put superglue on wood, I apply a wash of 75%Lacquer Thinner/25%Lacquer... this keeps the superglue from staining the surrounding wood, and you can't tell the lacquer has ever been there after you finish sanding the piece.
I use Loc-tite thin Superglue from Wal-mart. I've never tried the epoxy mixed with anything other than crushed turquoise, but I've thought about it a few times. And it should work well.
If I'm filling a small crack that I want to be black, I lay a line of CA, then just rub the powdered coffee back and forth, across the crack. Otherwise, I just use super glue and sand with 120 grit, like someone just said in one of these posts.
If I'm filling a larger opening, I use a pallette knife to force the grounds into the crack with the CA. (I clean the knife with acetone.)
There's a lot of good stuff in these posts. There are a lot of different ways to do it, so just try a few, and find out what works best for you.
Jim Swank
>I've found the little tubes of CA at Walmart, a blister pack of 4 for $2, the best value for this purpose. Small doses, cheap and handy, and if one hardens before it's used up no great loss. If I were using it for structural strength as a glue, I'd go with a name brand like Hot Stuff.
I use decaff instant.
Don Henthorn
