We value your privacy.
Thinner and more delicate would be great as Jamie advises if you can, but to me the finial's shape is OK although it needs sharper detail. Try another one with the same shape, and sharpen the inside and outside corners with a honed and polished tool. Lay off with the sandpaper except for a little 400 grit sanding with the grain (lathe off) and that should make a big improvement. If you work on your tool technique and use scary sharp tools, you don't need less than 400 grit to start with.
To polish a tool's edge, use white diamond buffing compound on an MDF wheel mounted on an arbor chucked in your lathe or drill press. Or just a flat piece of wood, rubbed with the compound, and used like a hand strop works fine.
