We value your privacy.
Well here's a funky bowl that I made several weeks ago that is similar, but out of the ordinary for me. If that makes sense. Curly soft maple. 7" diameter. Wide rim and chunky body as usual, but I added a bit of color to it. Sadly, the photo doesn't show the color as it really is. It looks like an aqua blue ocean really. I need to thank Art Liestman for some help on the coloring. I love his skill at coloring and would love to someday be as good at it as he is...I have a ways to go, but it sure is fun to play around with.
I used some black dye, then sanded it off leaving it in the endgrain of the figure, then added a couple of different Prisma Marker colors. The foot is colored as well. I'm still not sure about the final outcome of this one.
I tried a different finish on it that I'm not crazy about and that is Watco liquid finishing wax (satin) in the white and orange can. It's just too flat to me. It feels good though!
Any and all comments welcome. I have my thick(er) skin on today :)
I think the round shape works great, the rim is too wide for me or it needs another detail in the rim for my eye....hmmm, can you carve ion the flat of the rim through to the undyed wood? I think a contrast of a design on the rim might add to the look, maybe something similar to your detailed sphere's???
>Nice bowl Jennifer. I like adding color to pieces also.
Lighting is the reason the upper rim looks different. If you look at the back ground it is lighter right above the bowl. If you look at the camera to bowl position and think about a billiard shot you will see that the light from the hot background is bouncing off the rim and back at the camera. If you can move the light that is causing this hot spot on the background it will darken the color of the rim and make it more accurate. I'm guessing it's a top light that is doing that. Moving it forward toward the camera may take care of the problem.
Na..I'm not going to do another thing to this dude. I think carving may goof it up by fighting with the beautiful figure in the wood. I wish now I would have used some sort of oil finish to pop the grain more. When I put the wax finish on it, it initially did pop the grain and looked better than it does dry. I figure I shouldn't put oil on top of the wax finish now...even though it is super thin wax.
I really like this piece. When I first saw it, I thought the rim was a separate piece that had been glued on. I really like that look. I think the color works well and I like the little bit of natural wood left on the inside just under the rim.
I am getting more and more into less and less functional pieces and frankly, this one fits right in with my current thinking. Thanks for posting the pics, I really like it.
>Jennifer if your light box has a top you can change the direction and intensity by placeing white or black paper on the top to change how the light goes through or whether it even goes through at all. Wire screen can also be placed on the box to change lessen the intensity of the light in certain areas.
Bascially anything you do to the outside of the box will change how the light gets through. You can also add mirrors on the outside to bounce light through.
Since you need a little less light on the top place a piece of paper or cardboard on the top to sort of shadow the background. This can also be torn pieces of paper if a solid sheet is too much. Then take a mirror or cardboard covered in aluminum foil and bounce light back into the front of the bowl. If you bounce direct sunlight you will get a lot of light, maybe too much. You can try to bounce the light through the panel or reflect light from the inside back to the front of the bowl. You can also bounce light off of a white card if the aluminum is too much.
There are a million little tricks to change how the object looks. You just have to learn to see what the problems are. Once you know what the problem is you can usually come up with a solution to change it.
Interesting shape, with such a pretty wood, if It was my bowl, I would not add anything to it just a nice shape and let the wood talk, I can see adding interest in a piece with blah wood, then yes, dye it or carve it or burn it, whatever... but that's just me.
Pretty wood, nice shape, but the color doesn't do a thing for me, probably looks much better in reality, but maybe a deeper darker blue might improve the look, I don't know, just try some more.
>I really appreciate your candid remarks. It's always great to get constructive feedback. It really helps me see things that I can improve on and perhaps try on future pieces. Thanks so much!
