We value your privacy.
Here is one of the logs I picked up in the neighbourhood and I don't know what it is. The guys I got it from was told it was a cottonwood but the pictures I've seen of c.w. are very different than this. I am think some sort of poplar but it didn't grow really tall or straight. When it was still in the ground it had me think ait was a birch of some sort. The bark is kinda thick and grey not thin and papery like a white birch. Wood is softer than walnut, harder than pine (not too broad a range eh?)
>Couple comments on that... I've seen some of the higher branches on Cotton wood look like that before they develope the thicker Bark on the outside. I think it's a mating of poplar and cotton wood. The other option is if it doesn't look like birch it might be Aspen?
That center looks red almost like blood. If so it is box elder. It is kind of soft white wood with the pith area streaked with red. It is quite interesting in boards or turned in a bowl but the sunlight will turn the red to a brown unless sealed with a UV protectice coation.
Unfortunately, no. It's definitely not box elder. It's one of the trees I DO know. It's the poor photo that makes the centre look red. It's actually a dull brown.
Still thinking it's some sort of birch and will be looking into the aspen option.
First, if you really want any help with a chunk of wood, you ought to tell us either where you live, or better, where the wood came from. There are trees that grow out in California that I've never even heard of, and Maine has different trees than Arizona, too.
there are also ornamental species that are planted as part of a landscaping scheme that are WAY out of place -- like the Magnolia someone gave my wife, which can survive and flower here in a sheltered, south-facing spot, but is certainly not a native plant to these parts.
All that aside, I'd say from the looks that you have some White Poplar, though I have even seen some Quaking Aspen that had that bark. These are closely related to the Cottonwoods. If the bark is quite soft, easily damaged with a thumbnail, and the wood has a characteristic smell (can't really describe), you would most likely be in the Populous family. A dead poplar that sits around a while will have a distinct, kind of nauseating smell to the wet, rotting, inner bark. Birch would have a wet, cork-like inner bark and a sharply defined thin, tightly-layered outer bark, which I don't think you have. The darker center is probably why the tree was cut down -- looks like a dying tree to me.
Another tree in the Populous group is the Balm-of-Gilead tree, or Balsam Poplar, which have very sticky, upright, resinous buds, and a strong, pleasant smell.
>It looks like the fast growing hybrid popular we planted 20 years ago and cut down last at about 60 ft tall. We have quaken ash here at the farm in se ohio and it is very soft. Softer than pine.
>The texture of the bark looks like aspen. I can't tell exactly from the picture but if it is gray, it is not aspen. Aspen is a greenish colored bark with a white powder covering. Eventually the white powder comes off and you have the remaining greenish colored bark. Aspen grows above the 8000 ft elevation. Did it come from that high up?
Well, Duh! I never thought to tell you where I live. Now that you mention it, yup, seems like pretty important information. I live just outside of Toronto. I am liking the poplar/aspen idea.
I'd vote for the poplar, too; ours look a lot like that.
A number of years ago I picked up some poplar blocks that a road crew had left at the roadside and stacked them on my deck; a lot of it sprouted in the spring and sent out leaves (which eventually died since there was no root system to support the growth). If the logs you have are reasonably fresh, you might try setting some out to see if they sprout leaves, which you can then use for a more positive diagnosis.
It appears from the photo that what you have is an American Beech tree. I have several in my yard and just compared your bark etc. Seems a perfect match. While I'm not willing to go slice mine up to further confirm things, I turned the stuff once. Enjoy it while it's wet, the older(and drier) it gets the harder it'll be.
