Electric Chain Saw *LINK*
Wilford Bickel
>I have 2 huskies on the farm that do the heavy cutting work around the farm, cut firewood and of course cut my turning wood. There are times however that I need to trim the corners off of a blank or do a quick cut at the shop and don't want to go get one of the Huskies out and gas and oil it, crank it and then you have the noise and fumes that make it unusable in the shop.
I have been watching for the right sale on a small electric chainsaw and got lucky this morning. Cummings tool truck sale comes through the next town over about once a year. I was looking over the sale paper and found a factory refurbished 14 inch Remington electric that was coming with the truck. Just so happened my wife had her quilt guild meeting at the very civic center the truck was coming to and her meeting ended when they opened the door for the sale. Thanks to the LOML, I now have a Remington refurbished 14 inch electric chainsaw with 90 day warranty for the price of $29.99 plus tax!!! This should be just about right for knocking the corners off of blanks and I will be able to do it in the shop when the weather is bad!! You can order the saw from their web site but shipping is half again what the saw costs - if the truck comes to your area you may want to check into this unit. I'll post more about the saw when I get to try it out!
Cummings Saw Sale
Re: Electric Chain Saw *LINK*
Darryl Hansen
>Be careful you do not load it down. The drive is plastic (nylon). It is a good saw when used as you indicate you will. Keep the chain moving..
>Darryl is right. I had one and enjoyed it until a log I was cutting snapped shut on it and stopped the chain. Goodbye drive sprocket. It was under warranty and they send me another. That one "wore out" also. There was something about a bearing or gear that had about eight little needle bearing in it, loose. One of them escaped. That took all the fun out of it. I bought a Sears one that appears to be made by the same people and bought the extended warranty. I have run it with reckless abandon under the belief that sears will give me a new one when this one dies. It's pretty much bullet proof. Can't kill it. Come to think of it, you may have bought my last one. Keep the chain sharp and pamper it, you will enjoy the freedom form smoke and noise. Just plug it in and go.
Wilford Bickel
>Barry - I think you just convinced me to purchase the extended warranty on it. Something like %5.95 for one year after the 90 days or $9.95 for 2 years after the 90 days. I ran it a little while this evening and it by no means can compete with the 2 big huskies but for cutting the corners off of blanks, etc. - it is going to be great. No fumes in the shop in bad weather either!
Thanks for the advice from both you and Darryl!
Jimiles-Charlotte, NC
>Remington - Bought one Christmas 2005
I am now on my 5th or 6th replacement.
The motor overheats and starts smoking for no apparent reason sometimes with very little use.
The Arts Center I teach woodturning at went through 3.
At least Lowes has kept replacing them so far.
would'nt buy another
Leo Van Der Loo
Better start using it, mine didn't last 90 minutes
Leo Van Der Loo
>and that was after using a couple of small poulans, that outlasted the remington by 10 months, not good either, than one last try with the largest orange/yellow poulan, that one has so far seen about 5 years of use, still working, BTW poulan is Husqvarna owned.
Have fun and take care
Leo Van Der Loo
GaryG in MD
>I have a Craftsman 16" electric that I've used for trimming blanks for a couple years and have had no problems with it. I don't force it -- just let it cut at its own rate, which is plenty fast enough. It's great for all the reasons that have been mentioned -- a very useful tool, and in my case, at least, reliable. ...Gary
$10 Warranty
>I am wondering if buying the ten dollar warranty didn't put some sort of voodoo juju on the saw, mysteriously causing it to last longer than two years. If so, that's fine. It was worth ten dollars not to have to drive it back to the store and get another for two years and it would have been worth it to be able to replace it. Incidentally, when you take it back, put your dullest chain on it, because the new saw will come with a sharp chain. Just getting a sharp chain is worth something.
Darrell Feltmate
>my take on these electrics is they are all but the Stihl made by Electrolux, including the Husky. That said, they are great in the shop or for one or two cuts close to the house. I have a Poulan that I have used and abused for 3 or 4 years. It was less than a fifth what my Stihl 025 cost me and I figured it was disposable after the warranty. A Stihl electric is more than my budget would allow but it is not disposable and will last as long as a gas model. Could be we get what we pay for?
Around the Woods
Wilford Bickel
>Darrell,
I agree with you that they are only meant for a cut now and then such as knocking the 4 corners off of a blank that won't fit on my band saw. No way would I try to cut a good sized tree down or even cut one up with it. That is a job for the Huskies!! For $30 plus the $10 for a 2 year 3 month warranty - I can justify that just for the convenience of cutting the corners off of the blanks at the shop in bad weather in the winter. Like all tools after running a short time yesterday you could very quickly take on more than this unit could handle but for what I want it for it was a real bargain!
Leo Van Der Loo
Darrell here's a small part of a large report,
Leo Van Der Loo
>it gives you the names of the products made by Husqvarna, and a small header of the Husqvarna-Electrolux divorce.
Leo Van Der Loo
Charles B. Watson
>I purchased a Makita 16" electric chainsaw last year and it's great!
