Catalpa Finish
Roger
>I need some suggestions for a finish for Catalpa. I've had good luck with Danish Oil, but I'm wondering what other finishes might be good.
Thanks.
Catalpa Finish
Roger
Thanks.
Re: Catalpa Finish
georgetroy
>I suggest a sealer like Deft Clear Wood Finish, which is a lacquer first. Then apply your favorite oil finish. Catalpa is kind of porious and this will also helping the drying process. GT
Re: Catalpa Finish
Bill Turpin in WNC mountains
>One technique I have seen used on catalpa is to sand to 220. Use a micro-torch to burn the winter wood (dark grain). Then put shellac on the unburned summer wood, with an OFF lathe. This will seal the lighter colored wood from soot staining. Then sand with 220 and the rest of your grits. Use an air jet between every grit. Then finish with whatever.
Bill
Re: Catalpa Finish
Wolf Kiessling
>I like to finish catalpa with BLO and then two coats of dark colored Minwax. The BLO gives it a really pretty golden finish (IMHO).....
Like you, I also use danish oil extensively on catalpa....
Re: Catalpa Finish
John Leonard
>I use General's Salad Bowl Finish. John L.
