Bark Removal
Bark Removal
Bark Removal
Doug Reynolds in Seattle
>Got some plum from a tree that was felled this past weekend. Processed it into useable blocks but, did not have time to remove all the bark in some cases. Applied Anchorseal to the whole blank (except the bark). I plan on rough turning the blocks into bowls as soon as possible so the wood is still mostly green. Is not removing the bark going to cause big problems down the road? How long can I safely leave the bark on?
Re: Bark Removal
Re: Bark Removal
Gary Evans Tallassee, TN
>Hi Doug,
Not trying to be cute here, but the answers to your questions are, 1) It depends, and 2) It depends.
Both answers depend on the conditions where you will be storing the wood.
If you are taking it inside, then you face the possibility of too rapid drying, resulting in checking. Slowing down the rate of water loss by using anchorseal is a good practice to follow. Usually bark is a good substitute for anchorseal as long as you keep it away from bugs, usually not a problem indoors.
Usually its better to process the wood to where you could put it directly it on the lathe, but sometimes you have to leave it in "partially processed" form. As the bark dries and loosens, then remove it and add anchorseal to the exposed wood.
If you have to store it outdoors, then insects in the bark become a greater problem. Getting it up off the ground on some kind of platform can help. Putting a cover over the top to keep the sun off is also a good idea, but don't shut off airflow completely. Being able to adjust the airflow to the stack can also be helpful.
Since plum is a fruit wood, I would err on the side of caution as far as the rate of drying is concerned. Better to keep it a little more humid, rather than less. Best practice is to rough it out as soon as possible.
Good luck with your find. I had some plum a couple of years ago that had some very pretty pinks, lavenders and purples in it.
Gary
Re: Bark Removal
Leo Van Der Loo
If the bark is not to rough, you could paint the
Leo Van Der Loo
>bark also with wood sealer, it does help with the bug problem, as most bugs don't like to eat wax, and it might help keep the bark on longer also.
Have fun and take care
Leo Van Der Loo
Re: Bark Removal
Re: Bark Removal
Jimiles-Charlotte, NC
>Remember you aren't trying to waterproof it, just slow down and even out the drying process. Wood loses most of it's moisture from the end grain, very little from the sides.
Re: Bark Removal
Leo Van Der Loo
Would be nice if we could stop the drying all-
Leo Van Der Loo
>together, without degrading, there are some who keep the blanks under water, so it will not split. wood will split under the bark also.
Leo Van Der Loo
