Drill Rod. Allen Neighbors, you ...
Ed Moore
>gave me the push I needed to put a 5/16" piece of oil-hardening drill rod on my Oneway 1018 tool rest. I don't know how it will work, but it looks good and the PC-7 is still setting. I managed to break a piece on the banjo this morning and while I am waiting for the replacement to arrive from Oneway I figured the rest could cure and I wouldn't be inconvenienced.
I don't know if you saw my post late in your thread or not, but Brent English has been putting drill rod on the Robust tool rests. He sent me one to test drive and it worked great, so I encouraged him to continue with it.
So, I thank you for the push. ;^D
Ed
Re: Drill Rod. Allen Neighbors, you ...
Re: So Ed, did you harden it first or are you
Al Crandall (N.E. of Indy)
>So Ed, did you harden it first or are you using it soft?
Ed Moore
>Al,
I probably should have hardened it, but I chickened out. The 1018 is used for small items where bad catches are less likely to occur. I have decided that if this doesn't work out I will get a new tool rest, read up on what to do to harden it and try again.
I'm pretty sure that Brent English hardened his bars before he glued them in place because they seem pretty hard. And if this rest had been for the Robust I would have hardened them too.
Ed
Jorge Castaneda
>Al, Ed,
I would be afraid of braking my gouges with a hardened tool rest.
What you guys think?
TIA
Jorge
Jorge, the objective is to NOT have ...
Ed Moore
>catches. This isn't baseball!
I'm not concerned about that, but maybe I should be.
Ed
You can also buy pre-hardened rod
Brian Hahn in SW Wisconsin
>You can also get hardened rod from most industrial suppliers. You might need to search for "shafts" instead of drill rod. It comes in a variety of sizes and hardnesses. It costs a more than annealed rod, but it saves the grief of having to harden it yourself.
eliot d
>I'm sorry to be so dense, but why do you want oi -hardened metal on your tool rest? Isn't cast iron hard enough to support the tools? As for little nicks, etc. they are easily filed and sanded smooth. No? Do people sense an improvement in their turning with such tool rests? I'm not knocking it -- just interested.
Eliot, I think that ..
Ed Moore
>the tools slide easier on the drill rod and fewer nicks occur.
I did not harden the piece of rod that I used and in retrospect, I wish that I had done so.
Another reason that I chose to add the rod is strength. The 1018 toolrests are not heavy and some vibration can occur. The rest seems much more solid now with the rod glued on. I am looking forward to reassembling the banjo and trying it out. And if I have messed up, I'll get a new toolrest.
Ed
Re: Eliot, I think that ..
eliot d
>Are there any lathe manufacturers that provide tool rests of hardened steel, or with such steel rods attached to the rests? Would it add that much to the cost of the lathe? I'm thinking that if it's not expensive for them and it's better, why don't they do it? In other words, why should we have to do it after market?
Allen Neighbors
>Sorry I'm so late with the response, Eliot, but I had to leave Monday morning and didn't get back until yesterday (had to be there for my grandson's surgery).
The drill rod doesn't nick up as easy as the other steels used for tool rests... (cast iron included in my choice of the word 'steels' :).
I wish I could find 1/4" round HSS in 12" lengths. I've already got a couple of small nicks in mine.
You're right... it is easy to sand or file the nicks out, but I never think of that 'til I come upon one in a final pass!! By then, I hate to stop and file.
I took some pieces of oil hardening rod to a machinist, and asked him if he could harden them. He said yes, then when I got them back, they were crooked as snakes. They have to be heated evenly, in order to not warp.
Still looking for 1/4" HSS rod.....
Here you go Allen *LINK*
Bob Fawcett
>I have no idea what this is. Just found it with Google. Prehardened drill rod.
>Allen What are you doing that nicks your tool rest. I have 5 different tool rests and only have very slight marks on rare occasions.
You can buy prehardened drill rod but then you have to cut with abrasive wheels. I kind of thought that the rod would warp when heat treated unless you took a lot of precautions. I haven't tried to heat treat more than a few inches.
HSS may or may not be harder depending on how they heat treated what you buy. You can buy HSS totally annealed and it won't be any harder than the annealed drill rod.
Re: ???? who knows??? clutzy? ...
Allen Neighbors
>I don't know, John. I guess I'm a jerk. Everytime I attempt to use my skew, I get a nick one time or another... and I've got the lower-edge corners rounded.
I have a parting tool that has a rounded lower edge, and it nicks the rests.
Once in a while I get carried away while making a pass, and will have my toolrest a little too close, and the toolshaft will come off the rest, and the corners of my cutting bit will hit the rest... another nick, plus a bad gouge out of my piece.
I guess I'm just clumsy...
I'm going to check out the link in Bob's post... that may be best for me.
Thanks for helping me out, John. I surely don't want to get some chiwanese HSS rod. :)
Re: Thank you, Bob.
Allen Neighbors
>That looks like what I'm wanting to get my hands on. I should have thought of googling those words!!
Thanks again. I really do appreciate it.
Tommy Holmes
>Another idea. Would stainless steel round bar work? Oneway's toolrests are made of stainless and they are pretty nick resistent.
Re: Their curved toolrests are...
Allen Neighbors
>I have both of their curved toolrests. And neither one of them has a nick. It's there other rests that I'm using the rod on.
I guess stainless is harder than the 01 drill rod, isn't it?
That would be alright, too, I think. Hadn't previously given it a thought.
Thanks for posting.
