REAL MILK PAINT
Adding VS to a Jet Mini
Gary Evans Tallassee, TN
>Hi all,
Just got back from FL. Went down there after the SSS to help my brother-in-law move his stuff to TN. I had forgotten just what a long journey that can be.
Anyway, my friend in Key Biscayne GAVE me a 2 HP Grizzly dust collector which I'll be using in the new shop. He also has an older model Jet Mini (before they started painting them white,) which needs a motor. Rather than spend the bucks for a new Jet motor, he opted to purchase a new lathe.
Since he was out of town and since we had NO more room in the truck, I didn't try to put my hands on the lathe this trip, but I don't think it will take much conversation to get him to send it to me.
Now, the question is, if I get the lathe and add a VS motor to it, will I need to use the step pulley from the original motor? I know from my experience with adding a VS AC motor to my Woodfast that it is advantageous to be able to change the belts for really slow speeds, but is that necessary with the smaller pieces of wood that can be spun on the Jet? I'm pretty sure I have a 3/4 HP 3PH motor laying around. Just need to buy a controller for it.
Sorry for the ramble. When you haven't posted for awhile, it seems necessary.
Gary
Re: Adding VS to a Jet Mini
>I like the thought of having several speed ranges myself. May not be necessary with a small Jet, but it may come in handy.
Lan Brady
>Gary,
Glad you made it back home.
The best answer for the lathe is from "field of dreams"
Build it and you will use it(slight modification). I think you will find a need for every speed range the pulley set has to offer.
Lan
Bob Haines (Chicago Bob)
>Gary,
Penn State Industries has a var speed motor & speed controller for approx $100 to up grade the Jet mini. I have looked at it in the past and it seems like a reasonable deal.
Regards,
Bob
Ken Grunke from SW WI
>Gary, if you would be keeping the spindle pulley on the lathe, assuming it was yours, why wouldn't you use the motor pulley that goes with it?
If it would be difficult to adapt the original pulley to the new motor, how about an intermediate shaft (a countershaft), in pillowblock bearings, mounted where the original motor was. Then the 3 ph. motor below that, hinged so it's weight gives the needed belt tension on either side of the countershaft. It would take a dedicated stand, of course.
I'd say yes it's good to be able to have at least a low range and a high range of torque in a variable speed motor setup. If you are going to be turning both bowls close to the max capacity AND small items such as pens or light pulls, you may not be able to get the wide enough speed range without that capability.
But if just one or the other, then non-stepped pulleys should be good enough if their sizes were optimized for the desired speed range.
A small problem with Penn State VS Motor mount
Jerry Hall
>A friend just installed the Penn State variable speed motor on his Jet Mini and had the following problem:
You mount the motor on the plate that attaches the unit to the lathe. Then when the unit is mounted on the lathe, the top bolt on the plate does not clear the cross member in the lathe's frame. As a result, you cannot raise the motor enough to release the belt tension and change the belt to another set of pulleys. The solution was to reverse the supplied template for the plate, and drill three new holes for the mounting bolts.
Hope this is not confusing.
Re: A small problem with Penn State VS Motor mount
>I think I understand. You have to raise the motor mount relative to the spindle.
Does anyone know if the Penn State kit is AC or DC?
Thank to everyone else for their responses so far. The only reason I have the question is, as someone mentioned, the shaft of the motor I have may not be the same as the original motor. I haven't had the chance to measure them yet. I was just wondering whether it would be worth it to have the pulley bored out if it was necessary. Given the size of the Jet Mini drive belt, I doubt I could find a similar pulley with the correct shaft size.
Other responses appreciated.
Thanks,
Gary
>This is a good idea, Ken.
Certainly worth taking a look at. The other possibility that I have is that the original motor may be repairable. I haven't checked that out either.
Gary
