Bonding corian to wood?
Dominic Greco in Richboro PA
>Hello Everyone,
Last year I was given a small sheet of blue-ish corian (about 12" x 18" x 5/8" thick). And since that time it's been sitting in my shop gathering dust.
No back several weeks ago I posted a question here asking about a source for 2" dia. clock inserts. I got some great responses and I ordered three (they were so inexpensive I figured that in case I wanted to turn a base for one, I could).
So here I am in my shop, holding a clock insert and trying to figure out a way to make a nice looking "desk clock". So I turn and out of the corner of my eye I see the Corian. Then I see my box of burl scraps. Then this idea comes to mind. The Corian is too thin to hold the clock insert by itself. So why not turn a base from some burl, and use the Corian as an accent inlay! I'm thinking of turning a burl "platter", about 4" to 5" in diameter, then gluing a 3" dia disc of Corian to it. Drill your 2 1/4" dia. hole for the clock insert, add some details, polish and your done!
Now, my question. How can I bond the Corian to the wood? I assume that the wood will move (with seasonal temperature shifts) while the Corian will not. Or is this an issue at all?
Thanks in advance.
See ya around,
My ugly mug
Dominic
Re: Bonding corian to wood?
John Veerkamp
>Dom,
Jan Manuel who frequents here does corian work and uses CA glue. Corian counters are assembled with CA glue, but are installed with silicon adhesive. I think that if your wood doesn't have too much movement that CA has enough flexibility to hold.
John
Re: Bonding corian to wood? *LINK*
JanManuel
>I'm normally gluing Corian to more Corian....and CA glue works fine. Wood movement in small pieces isn't really that much, and if your burl is good and dry, I wouldn't expect that to move like a flat sawn board anyway.
One thing I learned early on is epoxy doesn't stick to Corian at all...CA glue sticks Corian FAST, so have everything ready and lined up before you apply glue....
http://www.jmanuel.net
>Dominic I've done quite a few ornaments with Corian inlays or segments. I just use 5 minute epoxy.
Mike Cunningham (Cape May NJ)
>Hi Dom,
I bond many different materials into recesses in the top of bottle stoppers which are of course wood. Early on I found that when using CA, eventually these materials would come loose from the stopper. I've attributed this to movement of wood, reduced porosity of the other material and brittleness of CA. I don't know if that's the reason but can't think of another. I'll also say that I haven't used corian in such an application. My remedy was going to a flexible silicon adhesive and I haven't had a problem since. If I'm not mistaken there is also a flexible CA glue and perhaps that would offer the same advantage as the silicon. Having said all of that and reading what Jan says, perhaps corian reacts differently than metal and mineral when adhered to wood and CA will be just fine??
Mike
Mike Stafford
Mike Stafford
>Dominic, there is a segmented woodturning artist by the name of Bud Latven whose work is some of the most remarkable I have ever seen. He frequently incorporates small pieces of material that resembles Corian into his work. You might contact him and see what adhesive he uses.
Andy DiPietro
Use Starbond Flexible CA glue *LINK*
Andy DiPietro
>Hi Dominic,
Good seeing Saturday. I think the best CA glue on the market is Starbond CA from CPH International. They now offer a flexible CA glue in several viscosities. Give them a call and explain your application. They are very helpful 1-800-900-4583.
There normal CA glues are gauranteed for 20 months and it is only $5.00 per 1 oz. The black CA is $10.00 per 1 oz. Ask them to send you a price sheet too. They also give you four no clog tips per bottle which really work. There is a $20.00 min order, so I usually buy 4 1 oz. and put three in my frig.
See ya!
Andy DiPietro
http://www.starbond.com/
Thanks everyone!
