LIGHTING
LIGHTING
LIGHTING
Bill Hale / The Wood Spinner
>There having been a couple of lighting threads lately I thought I would pose a question to any of our Eng. fellows.
My 500 watt halogens put out 10,500 lumens of light but lots of heat and I have to keep them at about 8 ft away from me .
As light deminishes to the square of the distance.
What would my lumen requirement be for a light source at 3 ft.
As you would guess I am thinking of going to led lighting.
Thanks
Bill in Casa Grande, AZ. Soon to be HOT HOT HOT
Re: LIGHTING
Re: LIGHTING
Gary Evans Tallassee, TN
>Hey Bill,
If you are correct that the intensity of light is inversely proportional to the square of the distance, and if you assume that your lights are adequate at 9 ft, rather than 8, then you should need the square root of 10,500 lumens, since 3 is the square root of 9. I think.
My head hurts, I think I'll go take a nap now. 8^]
Actually, I'm going to go call my friend who is a lighting engineer and see what he says. I'll get back to you.
Gary
Re: LIGHTING
Update: Straight from the horse's mouth...
>so to speak.
My engineer buddy tells me that the distance from the work surface is unimportant in determining the amount of usable light that you will receive from LEDs versus halogen lights.
Halogen lights may be rated at 10,500 lumens, but that is a measure of the total light output by that bulb in all directions. In order for that light to be usable, it has to be focused by the reflector. Reflector designs are notoriously inefficient. Consequently, your work space is only receiving approx. 30-40% of the light that the bulb produces.
LEDs, on the other hand, are already focused to some extent by the fact that they are mounted on a flat surface facing the area to be lighted. If the lens design is good enough, LED lights can be more than twice as efficient in delivering usable light to the work surface.
According to my friend, for your purposes you should be able to get by with LED lights that are rated at half the lumens of the halogens.
Gary
