Need help completing air filtration cabinet
Wayne Leach-NW Ontario
>Hi All,
I have a cabinet into which I installed a surplus furnace blower assembly which has the motor mounted within the blower. I hooked the motor up to 120volts using the black and white wires from the motor (there are 5 wires hanging from the motor). It runs great, but way too fast - if I put wings on it I could probably get it airborne.
My question is, these things usually start at slow speed, shift to med and then to high in a heating situation. I would like to run it slower but unsure whether I need any controller in between or just hook up the red wire instead of the black or maybe even the yellow wire?
Will I have a meltdown if I try this. Does these motors have the speed control built in???se
Amy help would be appreciated.
Thanks in advance,
Wayne
Re: Need help completing air filtration cabinet
Leo Van Der Loo
Leo Van Der Loo
>Hi Wayne, these furnace motors have the wire go trough the windings different as far as I know, anyway I have wired a couple up, and have put one on my high efficiency gas furnace, where it works on the lower rpm for air conditioning.
The slow speed is only a few hundred rpm lower though, not a whole lot, there should be a diagram with/in the motor to tell you which wires are for what, that's been my experience.
Have fun and take care
Leo Van Der Loo
Tommy Holmes
>I got one from an AC guy a few weeks (haven't made my box yet). The instructions he gave me were:
Black = High
Blue = Medium
Red = Low
Hope this helps.
Bob Fawcett
>I think this matches the one I have and use. Mine is made by Emerson Electrice.
You may find a motor plate on it. If you do - you can probably find a wiring diagram on the net. I found one for mine.
Re: I agree, Tommy...
Allen Neighbors
>same as I've found out using hook and crook. :)
Red seems to be the slowest speed. Black is higher... I didn't even try the others.
Re: Thank you to everyone who replied
>Especially to Tommy who nailed the wiring colors.
I hooked up the red and its much quieter running at slightly slower speed. Its working and should keep the dust level down.
Wayne
