Segments - Tip 1 - long
ebd
ebd
>Perhaps this is common knowledge but I thought it might be of interest to people just starting out. Sorry it's so long and the pictures of examples locate as replys to this post. Couldn't think of another way to do it.
When cutting segments it is common to flip the board to cut the next segment so as not to waste any more than the saw kerf. When cutting segments that will have their top surface exposed this can give unexpected results. This method works well on most woods when the grain runs straight through the length of the board especially then the end grain is either vertical or horizontal as in A&B below (Also see Example 1). When the grain is at an angle (C) the grain that shows in the turned object may differ in sequential segments (See Example 2). In certain woods, even if the grain runs straight the length of the board and is oriented like A or B there can be drastic differences in sequential segments (See Example 3 - left). To avoid this, cut the segment, flip the board and cut the smallest waste piece you can, then flip the board and cut the next segment (See Example 3 - right).
Re: Segments - Tip 1 - long
ebd
Re: Segments - Tip 1 - Example 1
ebd
>Canary wood segments cut by flipping - straight grain with no noticable difference between sequential segments
ebd
Re: Segments - Tip 1 - Example 2
ebd
>Bolivian Rosewood segments cut by flipping - differences in the grain can bee seen between adjacent segments. The differences are small but could have been eliminated by wasting a small piece as described in the post.
ebd
Re: Segments - Tip 1 - Example 3
ebd
>Lacewood segments - On left cut by flipping (note the severe difference between adjacent segments) - On the right cut by wasting a small piece between sequential segments (note that the grain is now the same segment to segment). In the board that the segments were cut from the grain ran straight down the length and the end grain was oriented like A.
Randy G
>EBD,
Thanks for this post. I've been thinking about doing some segmented turning and this was interesting to see.
