American Beech bowl 14"x5"
Leo Van Der Loo
>Finish turned this thin and let it warp inside a brown paper bag.
Comments welcome
Have fun and take care
Leo Van Der Loo
Leo Van Der Loo
Comments welcome
Leo Van Der Loo
Re: American Beech bowl 14"x5"
Leo Van Der Loo
Philip Duffy
>Well Done, Leo! I love the color and the grain combination. I hear that beech moves a great deal, even when dry. Do you expect to see that happen? Phil
Like this one a lot...
steve antonucci
>Did you finish turn it and then sand it to final finish by hand? Beech is a great wood for finishing and hard wearing for years of service.
Steve
Re: Translucence works....
Allen Neighbors
>Movement of the wood across different grain patterns is one of the things I like most about woodturning. I love warped bowls.
Looks good, Leo. Looks pretty thin, too, with that light shining through.
Thanks for the resonse Philip, it has moved a lot
Leo Van Der Loo
>already, as it is more than 1" narrower now than it is long, I don't know if it will move a lot still, it is dry now, relatively, it has some Tung oil on/in it, that should diminish the amount of moisture absorption I think/hope, we'll see, I turned some Beech candle sticks some years ago, and never noticed any movement later on, and yes a spindle is not a bowl.
Leo Van Der Loo
Re: Like this one a lot...
Leo Van Der Loo
>Thank you Steve, yes finish turned it, then let it dry, then sanded, power sanded as much as possible with the lathe on, and power sand than with the lathe off, and hand sanding still a lot, Beech does finish well yes, but it is pretty hard and dense wood, you do need sharp sand paper, it is now sooooo smooth, I would say it is slick.
Leo Van Der Loo
Leo Van Der Loo
>Thank you Allen, yes it moved as I was expecting, though I would have liked the heartwood ends to curve down some, but that didn't happen, instead it was starting to show initial checking, so I CA'd it, stopped it dead in it's track luckily.
Looks pretty thin, yes it IS pretty thin, flared the rim out so it has enough strength up there, I don't think it would survive if I left it that thin all the way to the top.
Leo Van Der Loo
Wayne Leach-NW Ontario
>Sure looks thin. I like wood when it changes shape, after all if you need things perfect you might as well have plastic???
Great work Leo, I am enjoying seeing your ideas come to fruition (is that a word?)
Wayne
Thank you Wayne, I'm just having fun, take care.
Leo Van Der Loo
