combo salt peppermill
bhenr99
>Does anyone have or know of any instructions on how to make a salt and peppermill combo unit? Thanks for any help.
Bob
bhenr99
Bob
Re: combo salt peppermill
Curly Smith
>I can think of three ways:
You could use the mechanism from one of these:
Olde Thompson Dual Combination Mill
You could one of the CrushGrind mechanisms from Penn State:
(as referenced in this post last week Re: Peppermills, the CrushGrind mechanism doesn't require a through shaft so you should be able to hollow the top part for a salt shaker, corrosion concerns notwithstanding)
Lastly, you could attach a note to a peppermill stating that it dispenses all of the salt that the user needs.
Bob Fawcett
>Beall Tool Co has crush grind mechanisms and instructions. The instructions include a salt mill. It is a separate mill. Sounds like you are looking for both mills in one block of wood.
I suppose you could use the short mechanism and make a 2 ended mill with salt on one end and pepper on the other.
bhenr99
>Sorry to confuse everyone. The top part will hold regular salt and the bottom to work as a peppermill.
