Hollowing tools
Hollowing tools
Hollowing tools
Don in Central Illinois
>I have been thinking of getting some hollowing tools and have looked at Kelton mini hollowing tools. They say they are good for up to 6" diam. but don't mention the depth. Also, the 1/2" Keltons don't mention depth or diameter capacity. I only hollow items in the 6" catagory now, because of lathe capacity, but would like to get bigger as time goes by. I need some sage advice. TIA.
Re: Hollowing tools
Re: Hollowing tools *LINK*
Sean Troy
>Don, I have been using most of John Leas hollowing tools for years. He has different ones for different size jobs. All easy to use and the price is quite reasonable. Give him a call and tell him what your looking to do.
http://www.woodturningtools.net
Re: Hollowing tools
Re: Hollowing tools
robo hippy
>I have the Kelton tools, the whole set, and it is easier to hollow 6 inches deep with the bigger tools. With 3/4 inch cutters, 6 inches deep is no problem. With 1/2 inch tools you get a little chattering. Figure how far can you reach over the tool rest with your bowl gouges before they start to chatter.
robo hippy
Re: Hollowing tools
Re: Hollowing tools
Ed Kelle
>I'm using the minis right now and at 5" deep it is just about maxed out, vibration is pretty good at the distance. Might be due to my wooden handles at that distance as well. As far as diameter, it all depends on how wide your hole is, I am going out to 5" D thru a 3/4 hole yet even the one with the double bend has difficulties hitting some points in the upper shoulder curve. Hitting the widest area OK with it though. Nice tools to have
Re: Hollowing tools
Steven Antonucci
General ideas on hollowing tools
steve antonucci
>As many people who know me will attest, I am a make your own proponent. If you are looking into a hollowing system, they get pretty price for what is essentially a piece of steel bar with a bit hole drilled in it.
I think you can find all kinds of steel at Enco for a few $$$, and drill out the end to hole a cutter. Some folks epoxy the cutters, some CA glue them, and I tap a set screw. Turning a handle shouldn't be a big deal.
I hollow a fail amount of wood, and the guidance I'll give you is as follows:
1.) thicker steel= less vibration.
2.) thicker steel= bigger entry hole
3.) you need more tools than you think to make most common shapes
4.) there is no perfect system
5.) I think there's an article in WC that details how to make your own.
Steve
Re: Hollowing tools
Re: Hollowing tools
RevDoug
>Thanks Sean. I've added the link to my favorites. May be giving him a call before long.
Turn 'em round,
Re: Hollowing tools
Bob Moffett
Bob Moffett
>I use Al Basham's hollowing tools and have been very pleased with them. I don't have any affiliation, just a satisfied customer. Here is a link to his website. If I don't get the link posted properly, just Google "Al Basham" and you will get his website.
http://www.albasham.com
Re: Hollowing tools
Re: Hollowing tools
ryker acuna
>I agree with everyone, I have made about half of my hollowing tools and bought the rest for specialty projects. Again though I dont think there is one complete answer. There are ford guys and there are chevy guys, Its all the same. Get something out of the WC and go with it. As with everything you will find go points and bad points.
Just like hollow turning its all in the feel of it. Good luck.
Re: Hollowing tools
Dick Hines
Re: Hollowing tools
Dick Hines
>I have the Kelton hollowing tools and captured rig. I picked up a Jamieson hollowing rig a month or so ago. I love it. Now I only use my Kelton when I have something I am doing free hand. They both have their place.
