Metals that can be turned on a wood lathe
eliot d
>I don't have a metal lathe but want to occasionally turn, bore, drill, etc, some smallish metal cylinders to use for reducers, adapters, sleeves, etc. For example I'd like to fashion an adapter, a couple of inches long, that would fit into a 3/4 inch female tenon and would have a 3/8 inch hole drilled into the other end to take a 3/8" rod. What is the closest thing to steel that I could still deal with on my lathe and in a drill press?
Re: Metals that can be turned on a wood lathe
Bob Fawcett
>I have never turned metal on my wood lathe, but others have. Some brass and aluminum can be done. Both can be alloyed and made pretty hard, so not all can be done with wood turning tools.
Brian Hahn in SW Wisconsin
>I've turned mild steel on my wood lathe. But you need to use a real low speed. Brass, copper and aluminum usually are easier to turn. Annealed metal turns easier than hardened. I had a work-hardened brass pipe section once that was almost as bad as steel.
Re: p.s.
>Standard HSS tools work well for turning metal. After all, HSS was developed and is used extensively for machining all metals, including steel.
Dave Shombert
Dave Shombert
>Eliot - A lot of people don't realize that it's possible to get a compound cross slide for a wood lathe. Delta and others made them specifically for their wood lathes years ago, I'm not sure exactly when. Maybe as far back as the 40s. I think the theory was that people would routinely use the machine for both wood and metalworking - at least, that seems to be the implication of the user's manual for my Delta slide - but apparently that idea never really caught on. I got my Delta slide off eBay and I had to make an adapter/platform arrangement to use it on my General. But it works great. I use it for wood, not metal, but that's another story. I can email you some pics if you like.
Dave Shombert
Elkins, WV
Leppikallio
>One possibility are these "cross sliding vises" like
http://www.grizzly.com/products/H0966
Would be easy base for custom made cross slide.
>Eliot Don't waste your money on the cheap cross slide vises. The tool chatters too much. Buy a good compound table from Enco however you would have to buy a tool rest and rig up some way to adjust it so it cuts dead center. This would get a little expensive but would let you do some mild steel machining.
Brass, Copper, Bronz and Aluminum can all be turned with HSS woodturning tools. You can cut or scrape depending on how you feel your skills are. If you have hardened brass or copper you can anneal it. You do this exactly like you harden steel. Heat to cherry red and then quench in water. I haven't found it necessary most of the time but every once in while you will run into some really hard brass.
You can drill steel on the lathe and Al Crandal gave a good description of how to regrind a bit so it doesn't pull the steel out of the chuck. It wasn't more than a week ago Idon't think. I haven't had any trouble using standard bits but I take it very slow.
You can also use a file while turning if you only need to remove a little metal to get it down to size. You need to clean the file teeth often. Put chalk on the file helps.
Re: Metals that can be turned on a wood lathe *LINK*
Ken Grunke from SW WI
>Take a peek at my Shopnotes blog which has some entries on turning metal with woodturning tools, both aluminum and mild steel.
Metal-turning on the Wood Lathe
