200+ woodworking book reviews
Hey Gary G from MD! *LINK*
>Ran across this in connection with another search. Thought of you and the remote power switch thread last month. Glue on a magnet and you might be good-to-go with this on the inexpensive (but not cheap) side of the issue.
mm
Lathe Power Switch
Re: Hey Gary G from MD! *LINK*
GaryG in MD
>Hi Mark,
Hey, thanks. Interesting link. That looks like a good possibility -- I'll have to talk to their tech people and see which way it works, although I would assume that down is off, which would be good. I'd probably glue on a bigger paddle to make it a bigger target.
They also have a link for a "safety switch", but it needs more explanation and is more expensive.
Thanks for the excellent tip.
Cheers, Gary
Re: Other One
>Yes, I saw the other switch they have with the bail handle, but it's near $40 and seems like it would have to be mounted in the vertical position to be used. That mounting requirement looks like it would limit application as a moveable switch too much.
Cheers
mm
