Dyed Poplar Pot
Dyed Poplar Pot
Dyed Poplar Pot
Bruce Forrest
>I recently found a source for some nice orange aniline dye. This is the result of some experimentation with it and some black. The piece measures 7 7/8 inches in diameter by 7 1/2 inches tall.
All comments are welcome.
Re: Dyed Poplar Pot
Question
Bernie
>Very nice Bruce the orange and black is awesome.
I just finished a poplar bowl 14" dia that I
dyed the outside blue. What grit do you sand to
after the dye is applied and are you using a
laquer finish? I am tempted to leave it alone,
I kind of like the raise grain feel on this bowls
outside.
Thanks,
Bernie
Re: Dyed Poplar Pot
Re: Question
Bruce Forrest
>I usually raise the grain with water before dyeing and then sand lightly with 320. Sometimes for effect, I dye and then sand off parts of it, cover with another color etc, but when all the dyeing is finished, I generally lightly sand with 400.
The finish is Minwax wipe-on poly. The poplar really soaks it up,so it takes quite a few coats. I lightly sand with 400 between the first few coats and with 600 between the last few.
Re: Dyed Poplar Pot
Thanks Bruce, I'll give it a try
Bernie
