HVAC compressor as vacuum pump
Randy Johnson Connersville, IN
>I�m thinking of adding a vacuum chuck to the list of upgrades that started with the new lathe.
I�m planning on using a HVAC compressor for the pump. A local contractor has offered to give me any one of several new-in-the-box compressors he has surplus. The little information I�ve been able to find so far mentions CFM in addition to inches of HG. The guy giving me the compressor says they will all pull the required vacuum but he didn�t know about the CFMs because that isn�t the way a HVAC compressor is rated. I don't want to waste a deal like this by trying to use a compressor that is not big enough (or maybe even TOO big)for the job at hand.
So........
What do I need to check for when selecting the compressor? One is refrigerator size and would be nice if I could use it since it is 110. I think all the rest are 220 and more along the line of what you would find in an outside AC unit.
Thanks in advance.
Re: HVAC compressor as vacuum pump
Leo Van Der Loo
Too small and it wont work at all, and larger than
Leo Van Der Loo
>needed, you only open the bleeder valve a little more, you would need a valve for that anyway, go for the big one, that's my advice.
Have fun and take care
Leo Van Der Loo
Re: HVAC compressor as vacuum pump *LINK*
>Randy,
I use a pair of 50-pint rated deghumidifier compressors as my vacuum pump. I get them FOR FREE at the local appliance repair shop when he junks old or defective units and removes their freon. I use two because their stand-alone CFM (a tad more than 2) is not sufficient. The refrigerater unit will not work; far too small. There's a good writeup on them on the AAW Forum website under the "How-To" section.
I use these things only because they are FREE, and I'm cheap. |;-}} If I were buying a vacuum-producing unit, I would, without question, buy a "real" vacuum pump. Check with Bernie at A&A re one of his great Robinair rebuilds at the link, and watch for such stuff on e-bay.
mm
A&A
Bill Turpin in WNC mountains
>Search WC for a thread started by Gary Evans on March 15, 2007
