We value your privacy.
How many cheat a fate worse than the eternal fires of turning hell by sharpening with the dreaded gray wheels? I really am starting to wonder if all this white/pink/blue stuff is as essential as some think.
>and I still use them on my 10" 1725 RPM grinder, no problem if you know how, have also blue and white wheels for my 7" 3450 RPM grinder, and dislike the need to true the wheels often, compared with the standard wheels that need only occasional cleaning and even less trueing.
>I learned to sharpen on gray wheels. I do have a set of white wheels and those are the ones I use most. The beggest problem with Gray wheels are they over heat carbon steels really rapidly. Since most of us turn with HSS today that isn't a problem. The other problem with gray wheels is they clog easily. Use your star wheel often to clean them.
If that's what you have I would continue to use them. If you upgrade to the white, pink or blue wheels I think you will enjoy sharpening more. You do have to true up the white and pink wheels more often but that only takes a minute or so. I don't have experience with the blue wheels yet so I can't speak of those.
I'm starting to experiment with belt sanders again. That's what i learned on because I didn't have anything else. I think with the the right belts and the right machine this would be a good way to go. You can quickly change grits and the belts don't need trueing. I haven't gotten far enough to find out the negative effects. The late Frank Sudol used a belt sander a great deal.
>I work with a dreaded grey wheel. When I bought my new Steel City 8" bench grinder last fall, it came with one white wheel, and one grey. I immediately bought a new Oneway blue wheel. Before it arrived, I had the new grinder set up, and found the Steel City grey wheel worked just as well as the blue wheels on my old 6" grinder. Ii can't say that for all grey wheels -- but, for the time being, the new 8" blue wheel remains in its box in the cupboard.
>Bill: you obviously are starting to get the picture. Most of the sacred "conventions" in turning are one person's preferred opinion that starts getting passed around as fact. I sharpened for many years on my 3" x 21" belt sander turned upside down & held in the vise because that was all I had. It was said that this method would wear down tools a lot quicker. Well my 5/8 bowl gouge now has about 1/2 inch of flute left and I replaced it this year after 20 years of use.
If the new one lasts that long on my came with the Delta grinder grey stones I'll be happy.
