Noisey Milwaukee RA Drill: Bearings, right?
Dominic Greco in Richboro PA
>Like A LOT of the fine folks here I have one of those Milwaukee Right Angle Drills (also called Close Quarters Drills) which I use for power sanding. While I take great pains to blow out the dust every so often, the drill started making noises a week ago.
I had the DC and Air Filter running and I could still hear the "whine" coming from the drill. After a short time, the quill started to become harder to turn. At that point I shut drill thing down. Upon inspection it became apparent that the sound was coming from the rear of the drill. Some research into the WC archives showed that this is the location of the bearing that tends to go bad with some frequency.
I found the thread where TD mentions the ENCO part number of the replacement bearing (Koyo bearing, part no. EE 1 1/2 2RSM3GSR)
Before I go and order the replacement bearing, I just wanted to ask some questions. I'd rather get all the necessary replacement parts at one time.
  1. There's little doubt that the problem is a bad bearing. Rough running, and the tell tale "whine" are all the clue I need to tell me that a bearing is shot (right?). Could someone confirm this?
  2. Is it the rear bearing the only one that should be replaced? There MUST be a front bearing. Does that usually need to be replaced as well?
  3. If so, does anyone know that part number, or the number of an applicable replacement?
Thanks in advance.
See ya around,
My ugly mug
Dominic
Re: Noisey Milwaukee RA Drill: Bearings, right?
Brian Hahn in SW Wisconsin
>I replaced both bearings at the same time. Why not? The drill is already open and bearings aren't expensive.
I don't know about the Enco part number. My bearings (indeed all bearings) should have a standard size designation on the side shields. I simply ordered that bearing type from my favorite supplier (McMaster-Carr). Be sure to order double-sealed bearings to minimize future problems with dust.
Bearings, right?
nailshooter
>I would think so. This is just a drill with a short shaft and transmission, so I would assume that the bearing in the back is a thrust type bearing that catches both axis of motion while turning.
Until a few years ago I always took my tools in for triggers, bearings, gears, etc. Now, bench time is so expensive that for any tool that costs over $150 and is a few years old, it gets replaced unless I can fix it myself.
But when I did have my tools serviced, the shop always told me to replace all the bearings when you replace any of them. First of all, to help deflect the bench fee, but second, the repair guys always told me that the older bearings left behind that don't run perfectly true anymore will wear out the ones that do faster.
To me this made sense, as I could imagine a shaft wobbling at one end shaking loose the other end that was held as tightly possible in place.
And then when I found out that bearings were only a few dollars each, I have saved myself more time in the long run by replacing anything that needs it while the tool is out of commission. Another set of bearings will only cost a few more bucks and in my mind, well worth it to hit them all at once.
Robert
>Dom,
Before you order the new double sealed bearings [get 2, they're small |;-}} ], you should check (read "mic") the shaft size of your drill's armature. Some of the drills are a true .250" and some are different. I have the high speed (2,500 rpm) model Milwaukee, and had to get different size bearings, plus I've been told there are several models of the 1,300 rpm version that have different shaft sizes. The outer dimension of the bearings are the same, but the shafts are different.
You should also be prepared to have to cut the old bearings off. Many are actually "pressed" on the shafts, and become fixed in place. A die grinder with thin abrasive disc does a good job, but you'll be very careful not to touch the shaft.
mm
Darryl Hansen
>Dom the rear bearing is not encased in grease the front one is. You should replace both of them. Get the sealed type they will last longer. Be careful when you reassemble the tollerances are very close for the wireing on the top side of the drill. You can download the schematics from Milwaukee or if you want I can scan and send them to you. I sent them to TD he was supposed to put them in the archives but I don';t know if they finally found their way there. They show the routing for the wiring...I use Boca Bearing for my bearings they are fast and inexpensive. The front and back bearing are the same animal...Darryl
Ed Kelle
>and when you go to put it back together, this will help. the trigger and assembly falls out when you open the case. Prop up the trigger when you reinstall and check out the orientation of the levers in yellow and green. Blue and red are brushes and if I recall, putting the blue one in first with the wire going under the motor made reassembly go easier. there is one short bolt in the case and it goes at the back of the head. good luck.
Bill Neddow
>Ed, that picture is worth a thousand words and is literally worth the price of the drill. One of the problems is that, when you carefully remove the lid, all the guts spring out. TD mentioned taking a photo like this, but I never got one apart without a bunch of springs and bits landing on the floor.
Thanks Darryl
>Darryl,
You wrote:
"You can download the schematics from Milwaukee or if you want I can scan and send them to you."
Thanks, I'd really appreciate getting a copy of that schematic. I can also go one step further. Since this is a often asked question, I want to document all the original information from TD, including the schematics from you, and the photo from Ed, and put them all in one article for Wood Central's Archives. This kinda' information is like gold!
That way, when someone needs this info again, it'll all be in one spot. Is Garrett still handling putting articles into WC's archive?
See ya around,
Dominic
Thanks Everyone. Article Pending!
>Thank you all for the help. You people are top notch!!
Like I wrote to Darryl, this collection of information is too valuable to go un-noticed. Many wood turners have this drill and have the same kind of problems with it.
I plan on putting all this information into an article, along with Ed's photos, Darry's Schematics, and TD's original part numbers. Once this is done, I will submit it for archiving in WC's Articles and Review forum. That way, when someone needs it, it'll be somewhere easy to find.
Yo Garrett! You still handling this kinda' thing?
See ya around,
Dominic
Re: Thanks Darryl
Darryl Hansen
>Dom since you are going to probably reproduce the drawings rather than scan them I have copied and sent them via snail mail so the quality will be as good as possible. I assume the address in the AAw directory is correct. Note there are/were two models. One had the reversing switch in the back you pulled or pushed on. The newer one is on the tip of the unit and swings back and forth. The older switch is probably not "findable" any longer unless your supplier has an old stock. Darryl
Got the package Darryl!!
>Darryl,
The package arrived in the mail today. I have a feeling that the schematics, exploded diagram, and wiring instructions you so kindly provided will help me out a great deal.
Now I just need to grab some shop time so I can take the old drill apart. When I do, I plan on taking LOTS of photos so that I can document the process.
Thanks again for your help.
Dominic
