Peppermils
Peppermils
Peppermils
DD
>I just looked at the peppermill entries and noticed that several of the peppermills (including the 1st and 2nd place winners) used grinding mechanisms that did not have exposed steel nut on the top to secure the top of peppermill. What type of grinding mechanism do they use that permits it to be used without the nut? After seeing those without the nut, the lines of such equipped peppermills seem so much better. Any help appreciated.
Doug
Re: Peppermils
Re: Peppermils
HarryB
>I believe those mills are the Crushgrind make. They are sold by a number of the mail order companies like Craft Supplies and Packard. You adjust the fineness (is that a word?) at the base. It is a ceramic mechanism so it will handle salt or pepper. The shaft is captured inside the top and does nothing but turn the mechanism. If you had a way to lengthen the shaft, you could make a pepper mill as long as your lathe could handle.
Re: Peppermils
Re: Peppermils
DD
>Thanks for info.
Doug
