Arrrgh� My live center bearing is toast.
Brian Hahn in SW Wisconsin
>Yesterday I was turning a 3� ball. It�s only the third one I�ve made and the others were two years ago. It was coming along nicely until the top bearing in my Nova live center decided to call it quits. The cup centers (drive and tailstock) left beautiful deep burn rings on the ball. I managed to finish the ball with a different live center, but it wasn�t pretty � having to use the other center, not the ball which turned out �perfect�.
I used a bearing puller to take the center apart. The Nova has 3 bearings and they were an interference fit on the shaft. I had to use a bearing separator to separate them and then pull them off individually. They protested every millimeter of the way. The top bearing definitely was toast.
I ordered a new complete set of bearings, but this is the weekend and they won�t ship until Monday. So they should arrive Tuesday just before I leave for the Badger Woodturners� meeting. Putting the new bearings on could be interesting. But that�s why they make jumbo sized �persuaders� (sledge hammers). Actually, I�ll use a bolt to draw them on to the shaft � maybe I should pick up a grade 8 bolt on Tuesday just to be safe. I might even have to stick the shaft in the freezer to facilitate the process.
Meanwhile, I�ll try running the live center with just two bearings � one at the top and one at the bottom. I�ve gotten so accustomed to the versatility and features of the Nova, that it is difficult to use a lesser live center. The Nova is 10 years old, so I certainly have no complaints about its performance.
The bottom line: $18 for bearings vs. $108 for a new live center.
The moral of this story: If you are mechanically included, a bearing puller is a very worthwhile investment. My $40 3-jaw puller has paid for itself every time I�ve used it.
Re: Arrrgh� My live center bearing is toast.
>Brian Mine is at least 10 years old and it's still running strong. I love my Nova live center, it's extremely versatile.
>I agree John. If I had to replace my live center, I'd get another Nova. Nothing else comes close in versatility.
Doug Thompson near Cleveland
>Brian, I'm glad you posted this to show that it is not difficult to rebuild a live center. Bearings are commom and can be picked up at any supplier. A puller is a good investment because any damage to the shaft is nothing but trouble.
Good post...
>what kind of bearing puller do you have? I only have gear pullers. I figure sooner or later I will have to replace the bearings in either my Mova or my Powermatic live center. I want to be prepared.
Bearing puller
>John,
My bearing puller is a 3-jaw puller, external jaws, spread: 3-1/4", reach: 2-1/8" and 1-ton capacity. I got it from McMaster-Carr for about $40.
I had to replace all of the bearings in my jointer-planer a couple of years ago and ordered it when I ordered the bearings. The planer cutting head had some good sized bearings and it handled those just fine. I think I had a clearance problem with one of the bearings on the planer head and had to get a bearing separator to get the bearing away from the end of the head. That item was about $29. Fortunately, McMaster-Carr has a facility in the Chicago area so I usually get next-day delivery as standard.
Thanks Doug
p.s.
>The brand is one of those industrial brands that you normally don't see in the consumer marketplace, and the quality is what industrial customers expect (and demand). It definitely isn't a Harbor Freight item.
jeff myroup
>Brian,
Along with cooling the shaft, you can heat the bearings. They should just slip on. We use dry ice and an oil bath at work.
Jeff
>That dry ice and hot oil bath combination sounds like what I'll need for this project!
