Hut Crystal Coat
Hut Crystal Coat
Hut Crystal Coat
Carol in Illinois
>Hi, all. Newbie turner here.
I'm trying out a variety of finishes, and one I've got is Hut Crystal Coat High Gloss Formula. However, it seems to me that I get the glossiest (is that a word?) finish from tung oil... So I was wondering if there is a secret to using the Hut. I've followed directions on the bottle to wipe on just a little while the lathe is stopped and then work up a warmth with moderate pressure with the lathe in... and used a couple of coats... But I've also read people talking about 5 or more coats of some finishes. Any suggestions or tips?
Thanks in advance.
Carol
Re: Hut Crystal Coat
Terence Rice
>If you have a V S lathe apply the Hut Crystal Coat with the lathe turning slowly. (If not stop the lathe.) Then turn the speed up to around 2000 RPM and get the piece hot with firm friction.
On my pens I apply 2 coats of CA glue while turning around 200 RPM then buffing with 0000 steel wool and finshing with Hut. It gives a nice polish and the CA protects very well. By the time the Hut wears off the natural oils from the fingers have given the pen its own sheen.
tm
>I agree with Terrence,
Friction Polish needs friction & heat to gloss up.
I crank it up to about 3000 RPM and apply firm pressure on the cloth.
I try to stop before it starts to smoke.
Hut makes an easy to use wax stick ( looks like a thick crayon )that when used with their polish can really gloss up nicely.
I like using it because its easy to apply.
2 or 3 ooats give me good results depending on the type of wood
I'm finishing.
tm
Sam Scalzo
>Hi Carol.
For what it is worth, I use Mylands sealer first and then use Mylands friction polish. I get a very good finish. I buff at about 3000RPM. I have tried many of the others that are on the market including HUTs but I find Mylands the best.Sam
Thanks, guys.
Carol in Illinois
