Re: All you need to do is modify the grind of the
Al Crandall (N.E. of Indy)
>All you need to do is modify the grind of the drill slightly. I could do it in 5 seconds, but I will try to tell you what you should do. Soft metals, like brass and aluminum, can be grabby when drilling if the whole lip isn't engaged. You already know this. The reason it is so is because the spiral flute, by its very geometry, causes a positive hook angle to be ground on the lip when the drill is sharpened. This means that the drill may self feed in soft metals if there is not enough resistance in the cut to overcome this tendency, as in the case of drilling .011 per side. The solution is to grind the lip with a zero degree hook angle which makes it a scraper instead of a cutter. Hold the drill with the lip more or less vertical and touch the cutting edge inside the flute to the right side of your grinding wheel (the flat face). It won't take very many sparks to accomplish this. The flat you ground along the lip, on the spiraling surface of the flute, need only be about 1/64" wide to be effective. In fact since you are only drilling .011 of material per side the flat need not be ground all the way to the center of the drill but might only be 1/16" long or so. Then the drill could still be used as before for all other materials because so little of the cutting lip has been changed. In essence, you have slightly "dulled" the lip which will be generating the chip, and you may drill without fear of "grabbiness".
Second alternative is a "straight flute chucking reamer" for about $14, but you already have the right size drill so go for it.
