200+ woodworking book reviews
Poplar Bottle
Poplar Bottle
Poplar Bottle
Bruce Forrest
>This is a poplar bottle-shaped hollow form. You could call it a big-necked cousin of the droplet-shaped pieces that I've posted. It measures in at about 10 inches tall. Not dyed because this wood had a bit of interest going for it. All comments welcome. (I just noticed a shadow in the picture. The right side is not flattened, the effect is due to the lighting.) If you don't notice it, forget I said anything.
Re: Poplar Bottle
Steve Kubien
"How to" question
Steve Kubien
>Hi Bruce,
How do you select the wood for these? Specifically, does the wood contain the pith when you begin or is the blank cut similar to a typical bowl/platter blank (obviously with different dimensions)?
I agree, this one needed no colouring. It is really nice the way it is. You've got this shape/form nailed down.
Thanks,
Steve Kubien
Re: Poplar Bottle
Re: "How to" question
Bruce Forrest
>The size of trees available around here dictates an end grain orientation. The pith is in the centre, but that doesn't seem to present too much of a problem with this poplar. I sometimes treat the underside with CA (after dyeing, if is is to be dyed) just to be on the safe side.
Re: Poplar Bottle
Steve Kubien
Steve Kubien
>That's sorta what I thought. Thanks.
Steve Kubien
Re: Poplar Bottle
Re: Poplar Bottle
Rick Davenport
>Nicely executed.
I see no need to dye this attractive hunk o' wood.
Rick
