Dust collector information
C.W.Stivison
>I am in the market for a dust collection system for my small shop. I think it was on WC that someone said it should produce at least 1000 CFS to do a good job. My shop is 12x20 and I would like to use on my lathe, band saw,and table saw. Any advice will be welcome. Thanks in advance.
CW
Re: Dust collector information
Re: Dust collector information *LINK*
joaz
>I have the 3hp Jet with the big silver filter on the top and bag on the bottom. Not sure what model # it is. It is upstairs in the attic and piped to both of my lathes. Does a great job. The filter has a thingy on top that allow's you to to turn blades inside the filter.
The blades knock down the heavier stuff into the bag and helps keep the canister/filter clean. Last i looked, it ran around $450.
Hope this helps.
http://www.maine-web.com/woodturning
Bill McWhirter
>The link should answer any questions you might have about dust collection. Best advice I can give is to use 6" lines. It really makes a difference in air flow.
Also, consider the noise factor, and realize that if you put it ourside it will quickly remove your heat/ac.
http://billpentz.com/woodworking/cyclone/index.cfm
>I had a 1.5 hp in my old shop that was your size (still have it also) that I had pulling a 4" PVC line with drops for my tablesaw, lathe and my router table. I had a trashcan separator in line to pull out all the big stuff. I could take the tablesaw drop and hook it up to my planer or my bandsaw. For my new shop, I bit the bullet and bought a 2 hp cyclone.
I couldn't agree more...
Peter Teubel
>From first hand experience, a cyclone with at least 6" pipes will make a H-U-G-E difference. My system is all 6" PVC and every drop is a "Y" to TWO 4" hoses (each individually gated). Both hoses go to a machine. If a machine only have one port, I leave another 4" port open somewhere downstream. That way I'm never choking off the throughput.
The cyclone will capture almost all the dust, which keep the filters clean and at max efficiency. Combined with a dust hood on my lathe, I do not need to wear ANY sort of respirator when power sanding. In fact, I don't even need to turn on the ambient air cleaner.
Yes, it's that good. I can actually see the dust travel 6" or so away from the hood due to centrifical force and then immediately get sucked back in...ALL of it.
I bought a 3hp cyclone and ran it *IN* my shop via about 20ft of 4" pipe to various machines. Stictly so-so performance. When I remodeled my shop, I moved the cyclone outside in seperate shed (which also houses my compressor and vacuum pump). Now its running thru at about 50ft of 6" pipe and the performance better by a factor of 3.
A good DC system is the result of the entire design, not the raw numbers of the equipment. Three biggies in my system are 1) large pipe, 2) large filters, and 3) never choke down the inlet(s) to less than the pipe diameter.
robo hippy
>A 2 stage system works best. Check out Oneida systems. They are about the best out there, but are a bit more expensive. Their 2 hp system would be great for your shop and it has a very small footprint. A paper pleated filter is better than the bag system, much easier to change, empty, and clean, and there is no released dust into the shop. If you want to put the collector outside, consider putting the filter inside the shop, as this will vent the cleaned air back inside rather than taking all of the cool or warm air outside (this was in the latest Fine Woodworking).Oh yes, one other thing, you want a remote starter, with a radio frequency beam rather than a infared type one. You can start it up from anywhere. Do keep the starter for the lathe up on a wall clip so it doesn't get tossed with the shavings. DAMHIKT. Having a spare helps also.
robo hippy
