Keyless chuck problem
Ed Moore
>I have a keyless chuck that has performed accurately and easily - up to now. It is frozen or seized, your choice of words, and my efforts to get it to operate have failed miserably.
Any ideas?
Ed Moore
Any ideas?
Try sticking the whole chuck in some diesel fuel,
Leo Van Der Loo
>or even WD40, or similar, for a day or two.
Than try to get it to loosen up, next best is get a new one ;-)).
Is this a chuck on a drill ??, I have had the screw inside come loose on one, and it prevented the jaws from closing, just have a look for that.
Have fun and take care
Leo Van Der Loo
Re: Try sticking the whole chuck in some diesel fu
Ed Moore
>This chuck is on a Morse taper and it is used in the tailstock.
I have doused it in WD-40 and it shows no interest in loosening. I MAY have opened it too far.
A replacement is possible and at this point it is probable. I use this chuck too much to be without it.
Thanks,
Ed
Leo Van Der Loo
>If it might become a total write-off, I would try a pair of waterpump pliers or pipe wrench and smack the chuck some while trying to close or open, back and forth, that's about all you can do, I would think, good luck.
Leo Van Der Loo
>Ed WD-40 isn't really a penetrant. Try a good quality penetrating oil and soak it really good for a day or so.
Bill Hale / The Wood Spinner
>IF THE JAWS ARE OPEN LOOK DOWN INSIDE AND MAKE SURE THE SCREW IS FULL TIGHT. iF IT BACKS OUT A LITTLE IT WILL STOP OPPERATION.
BILL IN CASA GRANDE, AZ
Keyless chuck problem -- solution?
Ed Moore
>Tonight at the regular meeting of Blue Ridge Woodturners I asked the "machinist extraordinaire" and club machinery guru, aka Bob Vaughan, about the chuck. He laughed and said something to Mark St Leger (whose school shop we meet in) and fished around and brought a piece of 1 x 3 with a hole in it over to me. The hole's diameter was that of the chuck grip and there was a slot sawed lengthwise through the hole and then about 3 or 4 inches further. Bob said to attach the board to chuck which is in the tailstock and secure it tightly on the chuck with a C-clamp. Then he said to smack the end of the board very hard, so as to generate torque. He described the board with C-clamp as a home-made impact wrench. Tomorrow I will try this.
Apparently this problem occurs more frequently than most of us knew. In any case, I have emailed Mike Hare in Georgia to see about a new chuck just in case. According to Bob Rosand, Mike is the one to see about keyless chucks.
Thanks for all the suggestions.
Ed
