Cutting Crystal glass
Ken George
>I have been asked to make turned stems for 2 champagne flutes to be used for a wedding toast. I have cut the stems off of inexpensive glass goblets using a file and a gentle tap. Since these flutes are not cheap, $40 each, I am a little reluctant to use the same technique. Anyone know the best method to cut the stem off of these full lead crystal goblets?
Thanks,
Ken
Re: Cutting Crystal glass
Rick Allen
>The best way is the same way you did with the cheap ones. If you want to put the glass in more jeopardy then you can use a cutoff wheel to work your way through the stem. While the cutoff wheel sounds appealing as having more control you actually create more stress for the expensive flutes.
You could practice the score and snap technique on a few more "cheap" glasses. You could take the expensive flutes to a stain glass person and pay them to cut the stems off (they will score and tap).
Good Luck
Rick Davenport
>Have you looked at the goblets at Craft Supplies?
Also, you find some high quality stem-less wine glasses at better department stores or kitchen shops.
Then you can simply turn the stem and attach the goblet with a flexible adhesive (I used clear silicon).
Rick
Twine and Alcohol
Jorge Castaneda
>Dip twine in alcohol, tie it around the stem light it and it will snap, sometimes it does not,, if so inmediately dip it in col water. It makes a very clean cut.
Jorge
Ken George
>Thanks for the responses. I will try the alcohol and string method this week end on the lower portion of the stem. If this results in a cleaner cut than the nick and tap I will use it.
Ken
Re: Twine and Alcohol
eliot d
>What an elegant solution!
;o))
Jorge Castaneda
>Thanks! Leave it to the third world...
Ken...
dwr
>... let us know how it goes and post a picture, okay?
Re: Ken...
Ken George
>The string and alcohol didn't work. I tried 3 times and nothing happened. The alcohol burned off the stem was still intact. Tried again and dunked in water after the alcohol burned off still nothing. Tried one more time and still nothing. Ended up nicking with a file and tapping with a small hammer. Works fine but leaves ragged edges. I will post a picture of the completed goblets/flutes when they are done.
Re: Ken...
Curly Smith
>I've done this before and it worked well:
How to Cut a Glass Bottle
You're not cutting a bottle but it should be the same concept.
What if...
dwr
>... you scored the stem circumference first (just like you do when you tap to break), then wrap the alcohol soaked string around the score line and then light it. I did something similar when I was a kid and used a thin wire instead of the alcohol and string.
Just a thought...
Dave
Re: Ken...
dwr
>Curly,
I had a wooden box and wire set-up as a kid...
Worked well, so long as the bottles were "fresh" and hadn't laid in the ditch for a few months! Those "aged" bottles made it real interesting... Never had a problem with 'fresh" glass...:)
Dave
