Re: Bubble in the finish
Ed Heuslein
>Howdy Bev: One thing I've learned about finishing over the years is that no matter what the turning is, and no matter who the turner is, the finishing methods are as numerous as the number of turners involved. Having said that, I first must admit that I have no experience with Lee Valley finishes. I have used a similar shellac based product, Hut Friction Polish, with good results. After initially sanding the blanks to 400g, I apply HUT PPP Brown to the bare wood and burn in in. This fills small voids. I then apply the friction polish with the lathe running very slow, a paper towel between my thumb and forefinger, and apply the polish, moving back and forth, never stopping. I turn up the speed and burn it in. I repeat this two or three times, depending on the wood. After waiting several minutes for it to dry good, I apply pure carnuba wax and burn it in in the same manner as the friction polish. Your fingers should get hot, but not burn a blister (DAMHIKT). Now, there are lots of other ways and I have no problem with any (well, most)of them.
I believe you are using too much polish and too much wax after the fact. The Liberon wax stick is really meant to be used on bare wood - it has some grit in it - similar to the Hut PPP sticks. All good products when used as intended I believe.
Now that I've stuck my neck out, chop it off folks!
