So far I've perfected one technique
Matt Berry
>Well, this weekend end up being THE weekend. I decided it was time to try turning a bowl. Yup, my very first bowl, I've done lots of spindle turning, and I had watched Bills bowl video numerous times over the last year+, it looks so easy, I can do it. Heck, it looks easier every time I watched the video. So I grab the chainsaw, fire it up for the first time this year, and proceed to cut my bowl blank, shortly there after I have a couple small bowl blanks, a mallet blank and a couple other blanks all out of walnut. Great, I prep it and get it on the lathe, true it up and get a nice profile started on the outside.
Wow, this bowling turning thing is pretty cool. Each step I was doing the same technique that Bill had showed me in the video - I even tapered the tennon to fit my chuck ;)
It was after this point that I seemed to have started perfecting a technique that Bill discussed but oddly enough didn't demonstrate. As per my annual safety check, I orbited my bowl for the third time yesterday, yup faceshield still works. I had orbited it twice on Sunday, both times falling harmlessly behind the lathe.
Oh it's rough out not rough up, well, at the third orbit I had pretty much finished the rough out / up. It is now sitting to the side waiting to dry so that I can "return" the piece to the lathe in 6 months. Hopefully I'll be nicer to the bowl and not feel the need to send it on a space trip :)
Re: So far I've perfected one technique
Re: Matt- each time you have a ....
Jamie Donaldson
>... problem, reconstruct the scene of the crime in order to determine what went wrong. Were you properly hollowing the inside from rim to center, flute aimed at 3 o'clock, and not center to rim, flute at 9 or 12 o'clock??
tek-Brunswick, Ohio
>If you�re tossing bowls around like that, it means you are letting the gouge dig into the blank. Make sure that you are letting the bevel rub the wood. If you can turn spindles you can turn bowls. The technique isn't all that different. I would bet that most of your catches are from hollowing out the inside of the bowl. You have Bill�s video. Pay close attention to what part of the gouge he is cutting with and how he has the flute oriented. Like Jamies dasi around 3:00 O-clock. Cut more with the tip and less with the wing inside. The transition from the side to the bottom is the hardest part. You really need to swing the handle of the gouge around quite a bit at that point and keep the bevel rubbing. Have fun you will catch on.
Tom
Re:tek- don't use that word"catch!" ;-)))
Jamie Donaldson
Matt Berry
>Reconstructing is always the fun part, I did that many of times learning the skew chisel, I did finally break down and bought the Allen Lacer tape which helped clear up a few things.
As for the bowl I orbited it twice on Sunday hollowing the inside, Which caused me to finally set it aside and review the tape, between you and the tape I know that at least on that day I had the bevel slightly misdirected (I need to get better lighting over there, couldn't see very well into the bowl). Monday I finished hollowing and went to ease the edges, well the final cut on the outside rim, due to my awkward angle I had too much of the side into it and we have lift off, smack, I love this faceshield.
The real question is, I currently have a 1/4" bowl gouge, and I've been seriously considering getting a larger one. Yes it would be more aggressive with the cut, but wouldn't it also help in being more rigid and give more of a safer cutting zone. I like the 1/4" for making rosettes, trivets or finer details, but maybe it isn't the best choice for roughing bowls and such? Just curious what everyone else thinks.
tek-Brunswick, Ohio
>A larger bowl gouge lets you work a little farther off of the tool rest.It flexes less than a small one. It also does take a bigger bite. A 1/2" or 3/8" bowl gouge is a pretty good all around tool. If I only had one I would pick a 3/8" Crown Pro-PM. Other turners have their own favorites. If you belong to the AAW review the sharpening DVD they came out with this year. I try to sharpen mine simular to John Jordan. If you have a turning club in your area, join it! You can usually get some good free hand on advice from some of the experienced club members.
I DIG what you say!
tek-Brunswick, Ohio
Matt Berry
>Wow, the AAW sure seems to have grown in popularity. The last time I had checked it out there weren't any that were close to me, but now there is one within 15 miles. I just might have to check it out. Thanks
Re: Matt- as a pro turner I have ...
Jamie Donaldson
>quite a variety of tools, but not a 1/4" bowl gouge among them. My workhorse gouge is a 1/2," and a companion should be a 3/8" to have a well rounded pair for most usage.
ebd
ebd
>Matt,
My first bowl gouge was a Sorby with a 1/2" U shaped flute (the stock it's made from is 5/8"). I still use it a lot. For roughing I think you want something sturdy. And with a light touch you can take off a very fine shaving.
Think about it this way. If you have a hammer that is too light and one that is too heavy, you will find much more control in driving a nail precisely with the heavy hammer.
Larry
Wally Dickerman in Arizona
>I, on the other hand have 1/4 inch gouge and love it. Works great for detail work around the rim, feet, etc. My workhorse is a 1/2 inch gouge. I have several with a couple of different grinds.
When I'm teaching classes and a student shows up with a 3/8 inch gouge, I invite him/her to use a 1/2 incher. They almost always prefer the 1/2 inch.
Wally
Matt Berry in Mi
>From the sounds of it I should be seriously considering the 1/2", should be able to really orbit that bowl then ;)
For making goblets, a ...
Ed Moore
>1/4" bowl gouge with a traditional grind is quite useful. Jimmy Clewes demonstrates this very nicely in one of his DVD trilogies. I recommend his DVDs very highly.
Ed
Re: For making goblets, a ...
Matt Berry
>So far I only have his turnaround video, I had been thinking about picking up his new set turn it up just haven't got around to doing it yet.
Since I've pretty much had to learn the lathe on my own (with the other parts of woodworking I at least learned most of it in shop class, TV, or friends and relatives) The lathe was a different story. So not knowing all the ins and outs I bought one a couple of years ago, and started turning. It was a lot of fun, even if I did get the occasional catch.
It was at that time I decided I should buy a video to learn how this is done. I was amazed at how fast Richard Raffen could turn a piece, through each video I payed close attention to the type of shaving they were making. That helped immensely.
I may have tested out my faceshield a couple of times over the years ( I am a firm believer in wearing one), yes I got a little to aggressive turning my bowl, sending it into orbit, but I still have fun doing it, and you guys help add to the enjoyment of this hobby 8^)
Ed Moore
>Matt,
For basic bowl turning, Bill Grumbine has some good instruction on his DVD/videos. I have Jimmy's first DVD and both of his three DVD sets. I feel that Jimmy's instruction has allowed me to grow as a turner and try things that I might not have tried otherwise. His bowl turning methods are similar to Bill's, so there are no inconsistencies. So, I urge you to splurge and get ALL of Jimmy's DVDs. ;^D
Ed
