We value your privacy.
>Today I couldn't stand it and went back to Joe's woodpile. They just delivered some fresh sycamore so a few blanks jumped into the truck before I knew it.
Now, don't laugh to hard... What in the heck is it! How does it turn green, any problems with drying (cracking), does it finish well.
Maple is by far my favorite wood to turn but this is the right diameter and easy pickings. Besides the last hat turned was for the WC exchange and I need pratice to give some demos this summer and fall. It will take about 6 or so hats to regain the skill to knock them out in 2-1/2, 3 hours like before.
Any thoughts about sycamore on the lathe... Thanks
>I was turning a small HF from a sycamore branch this evening. It has some spalting but still very solid. It turned and finished very nicely. I'll be looking for more.
>I've turned a little of it, and liked it. It has subtle, but beautiful, grain. Green, I've turned a few bowls from it, that ovaled a little, and only cracked where I had pith from a limb. Dry I haven't tried. Yet.
>I am glad I got the exchange piece before you into simi retirement on hats.
I love turning sycamore but I don't know how it will work for hats. When wet it will throw a lot of water. Be prepaired to clean the rust off your lathe ways.
Sycamore can be a nice wood to turn, though I find it a little more difficult to finish. We have finishing experts here like Russ, who can always help with that aspect.
The main feature of Sycamore, IMHO, is the spectacular fleck pattern in a quarter-sawn orientation. Real nice medullary ray formations in QS Sycamore look like Lacewood, which is a common nickname for it. So when I turn it, I try to use it for plates or platters, or very shallow bowls, and orient the piece in the wood to take advantage of the QS figure. Usually that means orienting the flattest parts of a platter along the medullary rays, or basically in a straight line between the pith and the bark. Fortunately, these trees can be up to 8 - 10 feet in diameter, and a 4' diameter tree isn't all that rare, so larger QS pieces and planks can be found.
While the wood isn't as hard as hard (Sugar) Maple, its tough and a bit "leathery". It also seems a little porous, and doesn't sand as smooth and glassy as harder, finer-grained woods. It also soaks up a lot of finish. For the last platter I made from Sycamore, I used a softer oil finish (Tried & True Original), as I knew it would get used that way, and could easily be replenished. I don't know how you would build up a finish to be high-gloss with this species, but surely some on the list have done that.
I have turned it, and it was smooth and finished very nice. I also re-saw it for my Shaker bent wood oval boxes. It bends nice, and again has a very nice look. But if the grain is not straight, I have had a few times where the bands (when steam bending) will fail and break.
>.. stringy and feathers during both turning and sanding, and the density varies widely from the availability of water when growing. It can move a LOT, but not overly prone to checking unless mistreated.It occasionally spalts radically, but degrades rapidly as well.
>I haven't turned a lot of it, but will get some more when I can. I had a piece that I thought had gone too far (age and checking) and was going to cut it up for firewood. Since it was a crotch, I cut it first as I would if I was going to turn it. Low and behold it had spalted and colored wonderfully. The next pieces I get I will intentionally let sit and simmer until done. Other than that, the color can be rather bland. It does seem to soak up huge amounts of finish. If you want the rays to show, cut and turn the blanks as you would a natural edge bowl. This puts the rays on the bottom of the bowl. If you cut the blank and cut from the center out (how I do most bowls to get the most and biggest bowls from a blank) you won't get the rays to show.
>It does appear that sycamore has the properties to turn a hat. I saw the fleck like beech and the redish brown heartwood. It cut with a chainsaw like it was a soft wood and very wet. I like the color from Gils example (good job Gil) and the fact it bends well. Oval is the shape needed for the end product.
Next year I plan to retire from my real job... then I'll have time for the fun stuff. Turning, travel and maybe move down south. Can't wait.
I've turned some Sycamore, find it a good turning wood, has some nice pinkish color in the larger trees and can have a real pretty lace flecking if cut the right way (1/4 sawn).
It's also a good wood to make things like food stirring utensils, as it stands the wet/dry cycles very well.
Other than that it is rather bland wood, but certainly a worthwhile turning wood IMO.
I've got a picture from the lace pattern, used the sycamore as a background for the bottle stoppers I made, with the Ruth Niles SS stopper cones.
>In addition to the other responses. Sycamore can be very heavy when wet ,but is fairly lightweight when dry.(which is probably why it's not the greatest fire wood) I think that you will find it will make a lighter weight hat than a maple hat of the same size.
>Leo, the quarter sawn sycamore is beautiful, it will be interesting to see where that pattern appears.
Tom, I've never turned one under 5 oz's so it might be possible now... I might have to turn one tonight after work or tomorrow afternoon. All work and no play makes for a unhappy woodturner.
